dwbaily Posted April 9, 2018 Share Posted April 9, 2018 Hey guys. Brand new to the forum. Awesome posts. My son just purchased a 2011 Legacy 3.6R Limited with only 44,000 miles on it and during the test drive we noticed a vibration/grinding sorta sensation in left hand sweeping curves in the road. Doesn't do it in right hand curves. My initial assumption is cv axle but knowing absolutely nothing about Subaru AWDs, I may be way off. Inside edge of tires worn pretty bad. Probably original Bridgestone Turanzas that came on it from factory. Has anybody had this happen or know what it may be? It came with a 3 month/4,000 mile warranty so will be getting to the dealer ASAP. Thanks guys for any thoughts/ideas. Link to comment Share on other sites More sharing options...
dgoodhue Posted April 9, 2018 Share Posted April 9, 2018 The inside edge of the tire shouldn't be worn excessively, that is indicative of the suspension being out of alignment or perhaps damage such as tie rod being bent. I would get that issue resolved 1st, it may be causing the vibration. Link to comment Share on other sites More sharing options...
dwbaily Posted April 9, 2018 Author Share Posted April 9, 2018 Thanks a million for suggestion! That's sorta what I was thinking, too. Gonna wear out that 90 day $100 deductible warranty the dealer gave us! By the way, it hit a parked car per CARFAX by the most previous owner right before they got rid of it causing minor damage. Maybe the body shop didn't align it. Link to comment Share on other sites More sharing options...
dwbaily Posted April 13, 2018 Author Share Posted April 13, 2018 The inside edge of the tire shouldn't be worn excessively, that is indicative of the suspension being out of alignment or perhaps damage such as tie rod being bent. I would get that issue resolved 1st, it may be causing the vibration. Link to comment Share on other sites More sharing options...
dwbaily Posted April 13, 2018 Author Share Posted April 13, 2018 Replaced tires and vibration/growl still there. Tell tale sign of wheel bearing sound. Waiting on warranty take effect to chase that. Actually does it when slightly turning wheel left. Link to comment Share on other sites More sharing options...
dwbaily Posted April 30, 2018 Author Share Posted April 30, 2018 It was the right front wheel bearing. Not covered under warranty. Oh well. Link to comment Share on other sites More sharing options...
sanhozay Posted May 1, 2018 Share Posted May 1, 2018 I'm having the same issue on my 2014 2.5i. Does it occur the most when making the even the slightest left turn when going highway speeds? I'm hoping it's not my bearing either Link to comment Share on other sites More sharing options...
dwbaily Posted May 1, 2018 Author Share Posted May 1, 2018 Yea the slightest turn of the wheel left caused it. You're putting a load on right front when u do that and that's what caused it. Subaru mechanic said our Legacy's are bad for wheel bearings to go bad. Link to comment Share on other sites More sharing options...
