rayeve Posted April 3, 2018 Share Posted April 3, 2018 Hi. I have an '08 Outback in North Carolina. When I took it in yesterday for "safety inspection" the car failed the included exhaust gas test because the tech"s computer (cheapie shop, by the way) failed to connect at all to the sensor that assesses the exhaust gas. Can anyone suggest technical reasons with the car that might have been a problem I should try to fix, or should I have just gone to the dealer to be sure the measuring machine was up to standards? Thanks. Ray Link to comment Share on other sites More sharing options...
WRX USA Posted April 3, 2018 Share Posted April 3, 2018 It could be a bad sensor. I also have an 02 WRX that I just smogged and I had to do some troubleshooting. I used one of these ( https://www.amazon.com/dp/B072ZRXZ2W/ref=cm_sw_r_cp_tai_ds.WAbP4VNZEK) because it will show readiness, read codes, and erase codes. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 3, 2018 Share Posted April 3, 2018 Go to a different testing station. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
