GT spec B rough engine after head gasket replacement
Posted
Hey guys
2006 GT spec B 148000km
Just had the head gasket, water pump and radiator replaced. As well as timing belt and valve for the cam timing, once this was all done the coils and plugs also. I’m getting like a rough stutter/misfire from 1000rmp to 1500rpm then the car runs great
No codes are showing does anyone know what may be the cause?
Posted
Take it back to the shop who did all that work for you and hold them accountable until they make your car work. That's what I would do (since I don't have a technical explanation for why its happening).
