relative4 Posted March 23, 2018 Share Posted March 23, 2018 My headlights are getting cloudy, again. I'm sick of polishing them every year, looking at buying a new set. When I last looked at this, the only new option was OEM @ $300 per side. I can now get aftermarket for $230/pair on eBay. Has anyone tried the aftermarket units, and if so how did they work out? Thanks! Link to comment Share on other sites More sharing options...
mdzowner Posted March 24, 2018 Share Posted March 24, 2018 i have the depo brand. they arent great. they look nice but my light pattern is all jacked up. ill likely try to improve it when the weather here gets nicer. could be an alignment issue Link to comment Share on other sites More sharing options...
Wasted Potential Posted March 24, 2018 Share Posted March 24, 2018 i have the depo brand. they arent great. they look nice but my light pattern is all jacked up. ill likely try to improve it when the weather here gets nicer. could be an alignment issue Would you advise buying them and send out OE to be built/upgraded and then just stash the depo? Link to comment Share on other sites More sharing options...
Ethanol Posted March 24, 2018 Share Posted March 24, 2018 Interested in solutions. My headlights look like crap but $600 does not sound appealing to me. Link to comment Share on other sites More sharing options...
jvick94 Posted March 24, 2018 Share Posted March 24, 2018 Unfortunately I've never seen an aftermarket housing that had as good a lighting pattern as an OE housing. I wonder though if the factory projector bowl and stuff would fit in the aftermarket one. That should give you the better lighting with a clear lens, but of course I'm sure the warranty goes out the window lol. Link to comment Share on other sites More sharing options...
apexi Posted March 24, 2018 Share Posted March 24, 2018 I'm thinking about touching up my headlights again sometime soon, but I'm wondering if you've been applying any sort of UV protectant on the lenses after polishing? Or if you still have to refinish them every year even with a special headlight sealant with a uv inhibitor. I guess ultimately what I'm asking is, what products are you using when you polish them? Link to comment Share on other sites More sharing options...
VespaGTS Posted March 24, 2018 Share Posted March 24, 2018 Solution: Do an amazing job of polishing them. Then install Xpel film to seal the surface. No more polishing. Xpel Link: https://tinyurl.com/y6vry92b Link to comment Share on other sites More sharing options...
relative4 Posted March 24, 2018 Author Share Posted March 24, 2018 Solution: Do an amazing job of polishing them. Then install Xpel film to seal the surface. No more polishing. Xpel Link: https://tinyurl.com/y6vry92bHow long have you had yours on? Link to comment Share on other sites More sharing options...
VespaGTS Posted March 24, 2018 Share Posted March 24, 2018 On my Tundra for two years. This is the next thing I am doing to my LGT. The problem is the surface once polished is still exposed to the elements. The film protects it from oxidation and debris. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 24, 2018 Share Posted March 24, 2018 Lamin-x makes the protective film as well. Link to comment Share on other sites More sharing options...
VespaGTS Posted March 25, 2018 Share Posted March 25, 2018 Lamin-x link: https://www.lamin-x.com/Subaru-Legacy-05-07-Clear-Headlight-Covers-p/s009cl.htm 20% off until Sunday with code: spring20 So $47.95 plus shipping Link to comment Share on other sites More sharing options...
zactek Posted March 25, 2018 Share Posted March 25, 2018 I've had the Depos on my car for the last 3 years with no problems. I do have an inexpensive clear film on them (not Lamin-x) and they haven't faded or yellowed. Light pattern is good and not affected. Money well-spent on E-Bay. Zack K. Link to comment Share on other sites More sharing options...
