Gbendezu Posted March 15, 2018 Posted March 15, 2018 Just an idea I’ve been having, how hard would it be to swap my 07 EJ253 into a 99-01 2.5rs? I’ve been told extremely due to the 07 block having avcs and being DBW and not DBC like the rs Sent from my iPhone using Tapatalk
eagleeye Posted March 16, 2018 Posted March 16, 2018 go blind transferring wire. probably be easier to put it in a pre 1995. at least you don't have to plug those into a state computer to pass anything. ...think dune buggy. VW to subaru power.
cseagle08 Posted March 16, 2018 Posted March 16, 2018 Or you could run it with a standalone ecu (haltech, etc) and the throttle from an '07 really easily, but that is gonna cost as much as (or more than) the motor itself.
Infosecdad Posted March 16, 2018 Posted March 16, 2018 How much of the engine do you need? Isn't 2007 CANBUS vs OBDII? That would mean you would likely need the fully wiring harness as well...
Gbendezu Posted March 17, 2018 Author Posted March 17, 2018 Or you could run it with a standalone ecu (haltech, etc) and the throttle from an '07 really easily, but that is gonna cost as much as (or more than) the motor itself. But that’d have the benefit of having a stand-alone ems in case I wanted to boost the motor right? Sent from my iPhone using Tapatalk
