Pilot1226 Posted March 12, 2018 Share Posted March 12, 2018 Hi, Regarding the oil filter, does it make sense to get something like this: http://www.formafunnel.com/ to make the process a little cleaner? Or is it pretty clean despite it being a horizontal filter? (And for those of you that use a Fumoto, do you guys have a metal skidplate down there for extra protection?) Link to comment Share on other sites More sharing options...
Wills03rexwagon Posted March 12, 2018 Share Posted March 12, 2018 Hi, Regarding the oil filter, does it make sense to get something like this: http://www.formafunnel.com/ to make the process a little cleaner? Or is it pretty clean despite it being a horizontal filter? (And for those of you that use a Fumoto, do you guys have a metal skidplate down there for extra protection?)I've never had any issues with the standard way, but it couldn't hurt Sent from my LG-LS993 using Tapatalk Link to comment Share on other sites More sharing options...
Pilot1226 Posted March 12, 2018 Author Share Posted March 12, 2018 Gotcha. On my 2.5 presently I get a bit of oil that drains out from the bottom after the oil is pretty much done from the drain plug. Link to comment Share on other sites More sharing options...
DugsSin Posted March 12, 2018 Share Posted March 12, 2018 Never had much of a problem with the oil filter other than a sending unit wire which is very close above the filter. When you remove the drain plug you better be ready for 7 quarts of oil coming out in around 30 seconds. now that can make a mess. Link to comment Share on other sites More sharing options...
Gravy Posted March 12, 2018 Share Posted March 12, 2018 No need for a skid plate with the fumoto. You can attach a fuel hose to the valve stem and drain the oil directly into a container with no spill. For the filter I just stick my hand in a plastic grocery bag and loosen the filter until it begins to drain slowly. Link to comment Share on other sites More sharing options...
Pilot1226 Posted March 12, 2018 Author Share Posted March 12, 2018 Cool trick. I use a red solo cup right now to take the filter off the 2.5, but it's pretty tight since it's in the "ring of fire" design. Not going to miss that one bit. Yeah, I'll most likely put a Fumoto on the 3.6. After quite a few oil changes I don't have the technique right and it usually gets all over the car, so that'll be nice and easy. Link to comment Share on other sites More sharing options...
