06SubLegTx Posted March 3, 2018 Share Posted March 3, 2018 Hello, So I get a intermittent 420 Cat code. Is this a sign that the Catalytic Converter is dying? My car has 106,000 on it. Thought? Has anyone ever used the Magnaflow cat? Results? https://www.magnaflow.com/products?partNumber=52305 Link to comment Share on other sites More sharing options...
Wasted Potential Posted March 3, 2018 Share Posted March 3, 2018 Is it a GT? Auto or manual? Link to comment Share on other sites More sharing options...
06SubLegTx Posted March 4, 2018 Author Share Posted March 4, 2018 Hello, Mine is a Automatic. None turbo. The code is very erratic. It can happen at different times, outside temps. It mostly happen when driving on the highway. There is no rhyme or reason when it will happen, days, to weeks to months. It's not consistent. Link to comment Share on other sites More sharing options...
relative4 Posted March 4, 2018 Share Posted March 4, 2018 An infrared thermometer is helpful. When warmed up, the downstream side of the cat should be about 100F hotter than the upstream side. If that's OK, the lower O2 sensor may be bad, or it may still be the cat. Follow the P0420 procedure in the vacay pix. Link to comment Share on other sites More sharing options...
06SubLegTx Posted March 5, 2018 Author Share Posted March 5, 2018 Can I ask. What is: Follow the P0420 procedure in the vacay pix.? Link to comment Share on other sites More sharing options...
