fastcar123 Posted February 23, 2018 Share Posted February 23, 2018 The intake system has 2 resonator son the intake. I was thinking of buying some stailess steel pipes from the auto parts store to delete those resonator Doing some research, some sources say these resonators help with performance, while others say they dont do much. So now I don't know what to do. So what about the aftermarket intake that can be bought for this car? Doesn't that system also remove the resonators? How does that system providepower for this car? Does anyone have the aftermarket intake system for this car? Did you notice an improvment over the OEM system? Link to comment Share on other sites More sharing options...
Yoda_One Posted February 23, 2018 Share Posted February 23, 2018 Welcome to the Fourm. Start here with the Mods http://legacygt.com/forums/showthread.php?p=4987582 Laughing at Oneself and with Others is Good for the Soul [emoji847] Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
surmiser Posted February 23, 2018 Share Posted February 23, 2018 The intake system has 2 resonator son the intake. I was thinking of buying some stailess steel pipes from the auto parts store to delete those resonator Doing some research, some sources say these resonators help with performance, while others say they dont do much. So now I don't know what to do. I've read the same claims about the resonators helping with performance, but haven't been able to either prove or disprove that in relation to our cars specifically. So what about the aftermarket intake that can be bought for this car? Doesn't that system also remove the resonators? How does that system providepower for this car? If you explore the forum, you'll find that several folks have done "milk jug" resonator deletes and I don't recall offhand any complaints about performance degradation. There are several aftermarket intakes for our cars (SSD, aFe, Kakimoto, etc), but none of them requires deleting the big milk jug resonator in the front part of the car, though most do delete any resonators that might be built into the intake tube. Does anyone have the aftermarket intake system for this car? Did you notice an improvment over the OEM system? The most popular aftermarket intake on this 6th-gen forum is the aFe Power Takeda Stage 2, which comes in different variants for the 2.5 and 3.6. Some have found that without an ECU tune, the Takeda can actually hurt performance, but I've documented in the 6th Gen Tuning Thread (https://r.tapatalk.com/shareLink?share_fid=5383&share_tid=248081&share_pid=5759450&url=http%3A%2F%2Flegacygt%2Ecom%2Fforums%2Fshowthread%2Ephp%3Fp%3D5759450&share_type=t) how with an ECU tune, it can provide modest power gain by itself, and also how it can provide decent power gain in conjunction with an axleback exhaust. What are your goals? @redvenetian on Instagram Link to comment Share on other sites More sharing options...
BradLegacy2017 Posted February 23, 2018 Share Posted February 23, 2018 The intake system has 2 resonator son the intake. I was thinking of buying some stailess steel pipes from the auto parts store to delete those resonator Doing some research, some sources say these resonators help with performance, while others say they dont do much. So now I don't know what to do. So what about the aftermarket intake that can be bought for this car? Doesn't that system also remove the resonators? How does that system providepower for this car? Does anyone have the aftermarket intake system for this car? Did you notice an improvment over the OEM system? Thats a good question. I remember doing a "snorkus" delete on my 00 Forester. It sounded awesome without the intake resonators..... Link to comment Share on other sites More sharing options...
fastcar123 Posted February 23, 2018 Author Share Posted February 23, 2018 I was actually not aware of anything other than the after intake. That is the only one that I could find anyway. My plan was to make a pipe that connected the throttle body to the stock airbox. Which would've deleted two of the resonators. My issue is that I just can't budget in $350 for an intake system. On my previous car (2011 mistubishi lancer) I only paid $190 for the intake. That's why I figured if I make a pipe then it cost alot less My overall goal is to get the most performance and fun out what I have. I don't intend of racing or anything like that as this is my daily driver. Link to comment Share on other sites More sharing options...
surmiser Posted February 24, 2018 Share Posted February 24, 2018 My overall goal is to get the most performance and fun out what I have. I don't intend of racing or anything like that as this is my daily driver. My 6th-gen is the only car I own, and is my daily driver, so I appreciate where you're coming from. But if your goal is really performance and fun, then you absolutely have to tune your ECU if you plan on changing the intake piping. Because that will mess up your MAF scaling, which greatly affects throttle response and power delivery. Speaking of which, if you're doing DIY intake tubing, you'll also have fabricate a hole and mounting point for the MAF sensor. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
fastcar123 Posted February 24, 2018 Author Share Posted February 24, 2018 My 6th-gen is the only car I own, and is my daily driver, so I appreciate where you're coming from. But if your goal is really performance and fun, then you absolutely have to tune your ECU if you plan on changing the intake piping. Because that will mess up your MAF scaling, which greatly affects throttle response and power delivery. Speaking of which, if you're doing DIY intake tubing, you'll also have fabricate a hole and mounting point for the MAF sensor. Actually I was going to use the stock air box which has the MAF sensor mounted to it. The piping that I want to change has no sensors on it. So what is tuning the ECU like for this car? On my last car is was close to impossible to do it yourself without knowledge of of coding and hexadecimal decrypting. Can I tune the ECU myself on this car with say a tuner or do I need to pay someone to do it for me? Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted February 24, 2018 Share Posted February 24, 2018 So what is tuning the ECU like for this car? On my last car is was close to impossible to do it yourself without knowledge of of coding and hexadecimal decrypting. Can I tune the ECU myself on this car with say a tuner or do I need to pay someone to do it for me? Once my car passes break-in I'll be getting it tuned by XRT. xtremeracingtuning.com May want to check them out. Link to comment Share on other sites More sharing options...
fastcar123 Posted February 24, 2018 Author Share Posted February 24, 2018 Once my car passes break-in I'll be getting it tuned by XRT. xtremeracingtuning.com May want to check them out. What page are their rates posted on? I tried to find it but it's doesn't really say anywhere. They also be mention a Cobb access tuner. Correct me if I am wrong but instead that a tuner that you plug into your car to program the ECU right from the device? If that were the case why could I not just use that? Link to comment Share on other sites More sharing options...
Da Roo Posted February 24, 2018 Share Posted February 24, 2018 There is a tuning thread with all your answers just FYI Sent from my LG-H871 using Tapatalk Link to comment Share on other sites More sharing options...
surmiser Posted February 24, 2018 Share Posted February 24, 2018 Actually I was going to use the stock air box which has the MAF sensor mounted to it. The piping that I want to change has no sensors on it. You have your MAF sensor on your airbox? No kidding. What exact Legacy model and year do you own? So what is tuning the ECU like for this car? On my last car is was close to impossible to do it yourself without knowledge of of coding and hexadecimal decrypting. Can I tune the ECU myself on this car with say a tuner or do I need to pay someone to do it for me? Do check out the 6th-gen tuning thread I linked to in my earlier post. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted February 25, 2018 Share Posted February 25, 2018 What page are their rates posted on? I tried to find it but it's doesn't really say anywhere. I was quoted: Engine w/ CVT Tuning - $395usd Computer setup/Logging Support - $25usd Link to comment Share on other sites More sharing options...
fastcar123 Posted February 25, 2018 Author Share Posted February 25, 2018 You have your MAF sensor on your airbox? No kidding. What exact Legacy model and year do you own? Do check out the 6th-gen tuning thread I linked to in my earlier post. Sure do. Mine is the 2015 premium 2.5i. I didn't realize that wasn't a standard thing Link to comment Share on other sites More sharing options...
fastcar123 Posted February 25, 2018 Author Share Posted February 25, 2018 I was quoted: Engine w/ CVT Tuning - $395usd Computer setup/Logging Support - $25usd That is a very high price. Or at least it is for me. Link to comment Share on other sites More sharing options...
fastcar123 Posted February 25, 2018 Author Share Posted February 25, 2018 Not to be rude, but is there a way to find the answer (can I tune it myself with relative ease) without searching through 36 pages? Or perhaps I may have missed something on the first and last 6 pages? Link to comment Share on other sites More sharing options...
ehsnils Posted February 25, 2018 Share Posted February 25, 2018 The general rule when changing something with the intake or exhaust is to get a tune since any mods will change how the sensors measure. On the intake the MAF and MAP will be impacted, on the exhaust the O2 may be impacted. So until you have a budget for a tune you should leave it as is. The resonators don't really impact your performance either. Link to comment Share on other sites More sharing options...
surmiser Posted February 25, 2018 Share Posted February 25, 2018 can I tune it myself with relative ease No. Sure do. Mine is the 2015 premium 2.5i. I didn't realize that wasn't a standard thing Mind sharing a photo? Because this is news to me. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
