blue wrench Posted February 18, 2018 Share Posted February 18, 2018 I'm looking for an arm/elbow rest cushion to put on the front door cards. As you may know Subaru puts a cushion there on other later models, so I wanted to see if anything exists specific to this model Legacy. Otherwise I've thought of having custom pieces made at an upholstery shop to stick on. http://i67.tinypic.com/51pjtd.jpg Link to comment Share on other sites More sharing options...
nevets27 Posted February 26, 2018 Share Posted February 26, 2018 I had the same thought. I'm either going to get a piece made, do it myself or get a shop to modify that part of the door card. My temp solution/testing for height and such, yes its ugly. Soo much more comfortable, feels weird to not have it there. It's slightly higher then the JDM dual console I have on the right but I plan to make that a touch higher maybe. Helps a bit with not being able to get the wheel a bit closer. Hopefully by some miracle I'll be able to do something about that also. Link to comment Share on other sites More sharing options...
