tonystark0007 Posted February 12, 2018 Share Posted February 12, 2018 Just install the kit my? To adjust caster can i do myself or a alignment tech as to adjust it Link to comment Share on other sites More sharing options...
d22597 Posted February 15, 2018 Share Posted February 15, 2018 I had mine adjusted at shop that has track setup experience. I had them add camber, max out the castor evenly and corner balance when they did the alignment. (Corner balance only applicable for coil overs) Link to comment Share on other sites More sharing options...
CPUNeck Posted February 18, 2018 Share Posted February 18, 2018 Why you can certainly adjust the caster yourself... but aren't you going to have the car aligned since you pulled the lower control arm off? I just did mine yesterday and plan to have it lined up tomorrow (if they're open.) One note though I picked up on the install doc that was subtle, you want to make sure the eccentric, "thinnest" wall part, is toward the vehicle's inside or outside. So for positive caster, have the eccentric closest the center of the car, for negative caster, have the eccentric closest to the out sides of the car... in either of those orientations you'll have 15-30 degrees of adjustment. Link to comment Share on other sites More sharing options...
