PurpleSNow Posted February 11, 2018 Share Posted February 11, 2018 Hi there I have a 93 legacy wagon LS. Im having problems with the maf sensor. I had it set a while ago by a friend on a C/O machine and it was very good on consumption. but since this week it was bad again. I eventually figured out the reading the fault codes since there was no globe in the cluster for the engine light. I had a 35 and 49 fault. 35 is the evap valve found a broken pipe going to it and replaced it. 49 is maf sensor and since I know it is faulty I would like to replace it. Now question is has anyone done a convertion to a auto maf sensor like on the newer cars. I can get ones with same wires and have their wiring but cant find the subaru wiring. Can this be done and has anyone done it. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2018 Share Posted February 11, 2018 Have you done a google search for that question ? Odds are you'll have better finding an answer on google. One of the Tuners here may have some info too, ask in the Tuning Forum 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PurpleSNow Posted February 11, 2018 Author Share Posted February 11, 2018 ive searched google and gont get much info but will keep looking Link to comment Share on other sites More sharing options...
Max Capacity Posted February 12, 2018 Share Posted February 12, 2018 Contact one of the Tuners, they may know about doing that or that you can't. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
