FreePalestine Posted February 1, 2018 Share Posted February 1, 2018 How difficult is it to change the fuel tank on my 09 legacy? There’s a nut that holds the fuel bump that has been broken, and turns out there’s no other way to replace it Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2018 Share Posted February 1, 2018 Just had the tank replaced in my 05 last Aug. The body shop had to drop the rear subframe to get the old one out. I had the fuel fill pipe replaced too. Along with a AEM320 pump and new basket assembly. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FreePalestine Posted February 1, 2018 Author Share Posted February 1, 2018 Just had the tank replaced in my 05 last Aug. The body shop had to drop the rear subframe to get the old one out. I had the fuel fill pipe replaced too. Along with a AEM320 pump and new basket assembly. was it a difficult job? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2018 Share Posted February 1, 2018 I think it depends on where you live. They did have to cut a whole in the frame to cut out one of the bolts with the nut welded in the frame rail. The nut broke free. When I saw the car up on the hoist, they had a tall jack stand supporting the rear subframe and diff. Parts and labor, right at $1400 plus the AEM and new basket assembly which were replaced in Dec. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
