mmm def Posted October 31, 2005 Share Posted October 31, 2005 I tried installing my cusco rear sway last night, I can get to the bottom endlink bolt but not the top, I did not take my exhaust down, does that make it any easier? I'd like to use my 14mm socket but it won't fit in there to turn. If I can get to that top endlink bolt I can finish the job. Any advice? Link to comment Share on other sites More sharing options...
Chief_Wiggum Posted October 31, 2005 Share Posted October 31, 2005 I think most people are dropping the exhaust. Some folks unbolt the mufflers, some just slide the system off the hangers and let it droop down. I'm not sure you can get the bar out with the exhaust in place even if you could unbold the endlink. Link to comment Share on other sites More sharing options...
inthedeck Posted October 31, 2005 Share Posted October 31, 2005 Just take the exhaust off of the hangar, that way you won't have to take it apart. Or, you could try an extension bit, for the ratchet...that's what I remember doing...so that it clears the exhaust. Good luck. And yes, you can get the bar out without taking the exhaust out...but it's a pain. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 31, 2005 Share Posted October 31, 2005 Just take the muffs off- it only takes a minute. Link to comment Share on other sites More sharing options...
edmundu Posted October 31, 2005 Share Posted October 31, 2005 I don't know if Dave mentioned it but he has the Borla catback, so it doesn't run in the same location as stock pipes do. So he might have the room to slide out the sway. As for the end link, I don't recall what I used, but I'm pretty sure I used a 14mm boxend wrench. Link to comment Share on other sites More sharing options...
mmm def Posted October 31, 2005 Author Share Posted October 31, 2005 I'll go to home depot at lunch and get a closed wrench or ratchet, i picked up some pb and some grease too. Yeah with the Borla there is plenty of room to slide the bar out. Link to comment Share on other sites More sharing options...
Xenonk Posted October 31, 2005 Share Posted October 31, 2005 unload your suspension, you have it loaded/compressed Keefe Link to comment Share on other sites More sharing options...
mmm def Posted October 31, 2005 Author Share Posted October 31, 2005 I thought you drive the car up on ramps? I had it backed up on my rhino ramps. Should I raise each side with the jack and loosen them? Link to comment Share on other sites More sharing options...
Mblock66 Posted October 31, 2005 Share Posted October 31, 2005 Dude don't buy anything. Just come over and I will get it off for you. We will put it up on ramps and get it off. You might need a deep socket 14mm but I have that too. Sways are really easy to do. I think they take like 45 minutes from start to cleanup. I don't understand why everyone thinks they are so hard. And I am so not a mechanic and it was still super easy and VERY straight forward. Maybe tonight you can come down, we'll talk Link to comment Share on other sites More sharing options...
Xenonk Posted October 31, 2005 Share Posted October 31, 2005 jack up the car from the differential and you dont even need ramps then. Keefe Link to comment Share on other sites More sharing options...
mmm def Posted October 31, 2005 Author Share Posted October 31, 2005 Can you really jack the car up from the diff? Link to comment Share on other sites More sharing options...
edmundu Posted October 31, 2005 Share Posted October 31, 2005 Can you really jack the car up from the diff? I do it all the time! Just don't try it if you are not on firm level ground. Also, it helps to have a wide stable jack. Link to comment Share on other sites More sharing options...
