vwgetta18 Posted January 22, 2018 Share Posted January 22, 2018 Changed my battery on Saturday afternoon drove and started fine but yesterday after driving my check engine light came on solid and the cruise control light is flashing on the dash Any one know what this could be? After doing research it seems like it could be the p0420 as I don't have a scanner to check it. Please help could I disconnect battery to clear the code or what should I do? Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 CEL always comes on in conjunction w/ flashing cruise. I believe. You can disconnect the battery to reset all monitors; just be aware if it comes back on your most likely have a problem. I'd say go to a parts store and use their free scanner to scan it yourself. Write down the code, go home and disconnect the battery, then drive and see if it comes on (and if it is the same code) or if it does not come back on. Link to comment Share on other sites More sharing options...
aj_mariner Posted January 22, 2018 Share Posted January 22, 2018 If you changed the battery and the car immediately starts driving funky, then you need to disconnect again and do an “idle relearn”. Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 24, 2018 Author Share Posted January 24, 2018 Tried disconnecting battery no luck with that got it scanned it's bank 1 sensor 1 Any walkthroughs on here for changing it I haven't seen anything Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted January 24, 2018 Share Posted January 24, 2018 There are several codes involving the upper sensor. What code do you have? Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 25, 2018 Author Share Posted January 25, 2018 I know one of the codes was p0134 no activity detected faulty oxygen sensor bank 1 and I can't remember the other code but it was similiar to that one Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted January 25, 2018 Share Posted January 25, 2018 read the sticky above about ECU codes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
