StevenDC Posted January 20, 2018 Share Posted January 20, 2018 So just got the wagon and at first two times only shut off when I had the wheel locked turning, giving no gas. Now with the weather being cold and third time it happened when I was stopped at a light. Today shut off like 4 times all at a stand point, did happen after the gas light came on but I know I have gas. So I’ll just be sitting there and the engine will just go off and all the lights just come on. Things I know about the car is abs light is on, steering is funky when I get closer to locking the wheels and steering jerks a little but I think I know what’s wrong with that, there’s times where I have the pedal down reving and car doesn’t really move that much, lastly car idles below 1000 rpm. Really just looking to hear about it shutting off so doing stay too much on what else I said. Link to comment Share on other sites More sharing options...
relative4 Posted January 20, 2018 Share Posted January 20, 2018 Symptoms described sound like the PS pump is seizing. Any noises? You could remove the PS/alt belt and try turning the pump by hand. Link to comment Share on other sites More sharing options...
apexi Posted January 20, 2018 Share Posted January 20, 2018 In your shoes, I'd look into the abs light and find out what codes you have stored. I wonder if one or more wheel speed sensors, or wheel bearings is bad, causing your issues. Have you replaced any of the wheel bearings recently, or done anything in that area? Link to comment Share on other sites More sharing options...
ehsnils Posted January 20, 2018 Share Posted January 20, 2018 Cold weather and idling issues on a 2005 can be the donut gaskets as well. Gaskets are between manifold and TGV or head. (I can't seem to remember where, but search other threads and you'd find it) Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 20, 2018 Share Posted January 20, 2018 Idle is supposed to be below 1000 rpm-about 800 rpm. Check the main loom plug above the turbo for moisture. It only takes a drop of water to cause different types of shorting and might be telling the ECM to shut the car off. Link to comment Share on other sites More sharing options...
StevenDC Posted January 20, 2018 Author Share Posted January 20, 2018 Symptoms described sound like the PS pump is seizing. Any noises? You could remove the PS/alt belt and try turning the pump by hand. There is a noise when I turn the wheel all the way Link to comment Share on other sites More sharing options...
ehsnils Posted January 20, 2018 Share Posted January 20, 2018 There is a noise when I turn the wheel all the way That is not really conclusive since it can be either an overpressure relief valve or the belt slipping. Just make sure you have enough fluid for the power steering in the canister. Link to comment Share on other sites More sharing options...
StevenDC Posted January 20, 2018 Author Share Posted January 20, 2018 Cold weather and idling issues on a 2005 can be the donut gaskets as well. Gaskets are between manifold and TGV or head. (I can't seem to remember where, but search other threads and you'd find it) 50 degrees out and it shut off on me today, is idles at 500 after warmed up and such. Link to comment Share on other sites More sharing options...
aj_mariner Posted January 20, 2018 Share Posted January 20, 2018 Was the battery recently disconnected for any length of time?? Also, since you know how to make it shut off...try turning the wheel to the limit with the car in Neutral and see if it still happens. Try to take known shut off scenarios and switch small items up to see if it still happens Link to comment Share on other sites More sharing options...
StevenDC Posted January 21, 2018 Author Share Posted January 21, 2018 Update, don’t believe the steering is the problem. Was trying my best to pay attention to what happens when it shuts off. Got to a light tach went back down to 500rpm and the dash lights came up and the engine was off. Seems when I really break it almost stutters that’s usually when it shuts off. Any suggestions based off that? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 21, 2018 Share Posted January 21, 2018 Have you scanned for codes? You may have more than one issue. I'd be curious to see if the abs code is vss related and if there are any cel codes. Link to comment Share on other sites More sharing options...
aj_mariner Posted January 21, 2018 Share Posted January 21, 2018 Try putting the trans in neutral the next time before coming to a complete stop and see if it still does it Link to comment Share on other sites More sharing options...
Infosecdad Posted January 22, 2018 Share Posted January 22, 2018 A bad vacuum leak can do that. Check all your hose connections, throttle body, small vacuum lines, etc. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 22, 2018 Share Posted January 22, 2018 Is it a manual or auto; you guys think this would make a difference on culprits? Link to comment Share on other sites More sharing options...
wbrawley Posted January 22, 2018 Share Posted January 22, 2018 Got an accessport? Mine would do that if I went in reverse when still cold, bumped up idling 75 rpm and it doesn't do it anymore. But mine was idling at about 400 rpm as well. Link to comment Share on other sites More sharing options...
StevenDC Posted February 1, 2018 Author Share Posted February 1, 2018 Quick update. Not sure if I mentioned my transmission was shifting off and delayed saw trans oil was low filled it. It leaks but I’ll get to in a couple days, anyways apparently that might have been it, car hasn’t shut off since I filled up the trans. Link to comment Share on other sites More sharing options...
