Zac88 Posted January 13, 2018 Share Posted January 13, 2018 Will these tires fit on stock suspension? I do a lot of gravel road driving due to having an acherage and farm I need to visit often and want some extra sidewall for a softer ride Link to comment Share on other sites More sharing options...
3.0r413 Posted January 14, 2018 Share Posted January 14, 2018 i cant guarantee but i think they should fit. i have a 3.0r with the bilsteins so its about 20mm lower than your car and it takes 235/45 just fine. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 14, 2018 Share Posted January 14, 2018 I'll say yes they will fit. I just took off the 215/45-18 winter tires on the Spec B wheels off my 1" lowered wagon and put on the 225/50-17 Nokian WRG3 on, I noticed I had to pump the jack once to get the Nokians on. So they appear to be taller then the 18's. So on a stock ride height I'm thinking you'll be ok. Just watch the first turn where you go to the steering lock in a tight turn. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 14, 2018 Share Posted January 14, 2018 I have 225/50/17 on my LGT wagon stock height. I have less than 0.25-0.35 inch clearance between strut and wheel... you're adding 1 inch in total diameter. Therefore 0.5 inch taller radius wise. I think it will fit. And if it does I would be scared of the clearance under sidewall flexing Edit: p4obably barely clear with spec B or Bilstein struts. But the spring perch is the pickle Link to comment Share on other sites More sharing options...
Zac88 Posted January 14, 2018 Author Share Posted January 14, 2018 Forgot to mention that I do have JDM SpecB RevA Bilsteins installed Link to comment Share on other sites More sharing options...
Zac88 Posted January 14, 2018 Author Share Posted January 14, 2018 Just measured and it looks like with my current winter tire setup of 215/50R17 I have 30mm between the tire and strut and from a tire size calculator looks like i'll have half an inch bigger sidewall which is like 15mm so I think I should be fine! Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 14, 2018 Share Posted January 14, 2018 Let us know how it goes. Know some tires bulge more than others also Link to comment Share on other sites More sharing options...
Zac88 Posted January 14, 2018 Author Share Posted January 14, 2018 225/45/R18 could also be an option Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 14, 2018 Share Posted January 14, 2018 I know you are set on trying something for more sidewall and protection on 18s, I cannot imagine anything larger than what I have unfortunately. Id advise buying a factory set of 17s for cheap and the same combo as Max for 215/50/17, i dont feel safe in aggressive turns due to minimal lateral clearance. Good news is these are winter only tires that I had a deal I didn't want to pass in on (basically free). Then again, I have not tried the combo on 18s, so my opinion is just that, no factual yay or nay. Sorry. Here are pics of 225/50/17... Edit: sorry I'm blind, you said you have Bilsteins. I think it'd fit then. Link to comment Share on other sites More sharing options...
