vwgetta18 Posted January 2, 2018 Share Posted January 2, 2018 Hello this morning after getting gas my sound almost didn't want to start it took a little while of cranking before it did start and when it did start it idled rough for a minute then went back to running normal. Wondering if it's my battery or the starter? I have a 2.5i legacy 2008 with 137000 miles on it recently changed the battery about 2 to 2.5 years ago not sure what to do about buying. Changed spark plugs around 90k on my car I'm sure it's time to change those also. Please let me know Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
aj_mariner Posted January 2, 2018 Share Posted January 2, 2018 Make sure the battery connections are clean and tight. Check the output voltage of your alternator. Then check battery voltage. They should be the same and above 13.8VDC IIRC. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2018 Share Posted January 3, 2018 Did it crank really slow? I just had the issue with mine, I changed the battery on Friday and it was if anything got a little slower turns out my starter was going out.. but kinda gave me warning signs before hand like nothing happens when the key is turned to start had to hit the stater to get the contacts to move to the starter contacts. Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 3, 2018 Author Share Posted January 3, 2018 Yes it did crank really slow I almlst thought it wasn't going to start and this weather here is nj does not help at all it's been 5-10 degrees in the am here. How much was the starter? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2018 Share Posted January 3, 2018 Yes it did crank really slow I almlst thought it wasn't going to start and this weather here is nj does not help at all it's been 5-10 degrees in the am here. How much was the starter? Yeah mine cranked so slow I thought i was going to get the clicking sound when not enough power.. it turned over reallly really slow. The starter was $107.99 plus $40 core but mine is a 5MT the auto might be more Link to comment Share on other sites More sharing options...
vwgetta18 Posted January 3, 2018 Author Share Posted January 3, 2018 Oh alright that's not to bad at all. Mine is a 5MT also. Did you change it yourself I'm going to try to get to advanced or AutoZone tomorrow to get the battery tested wish I had a voltmeter. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 3, 2018 Share Posted January 3, 2018 Take out the air box on the center and literally its wide open. I changed my starter in maybe 30 minutes. I changed the PCV while I was at it (on the passenger side). Even if LGT, almost same time. Removing an intercooler rather than s Air box Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2018 Share Posted January 3, 2018 I changed mine in about 40 min Link to comment Share on other sites More sharing options...
apexi Posted January 3, 2018 Share Posted January 3, 2018 I'm thinking it's your battery, but the starter is easy to replace. I didn't have to remove anything except maybe disconnecting the vacuum hose going into the driver side of the airbox. I replaced my oem starter after 215k just as a precaution, it still worked fine though. *I'd also make sure your battery connections are tight and clean too. Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 3, 2018 Share Posted January 3, 2018 So cheap might as well do both at once I wish my only issue was a starter or battery.... Link to comment Share on other sites More sharing options...
