Sololeggy Posted December 20, 2017 Share Posted December 20, 2017 So I'm swaping the trans on my 03 legacy gt and the driver side front axle will not come out of the hub took the axle nut out and banged on it for 10 min and took my air hammer and did nothing not sure if there is some type of pin holding it or something else but I was told by the last owner that it wasn't replaced, so could it be frozen in there? Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 20, 2017 Moderators Share Posted December 20, 2017 Go get a puller from local auto store, some of them will rent it to you. Tighten the puller, then hit the drive screw with a hammer. As it loosens, continue to tighten and hit with hammer. It will come out. Anti-seize the splines of the new axle to prevent it from getting stuck again in the future. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 21, 2017 Share Posted December 21, 2017 remove the pin that holds the axle into the transmission/differential housing 4:00 into it Link to comment Share on other sites More sharing options...
08SpecB_DE Posted December 21, 2017 Share Posted December 21, 2017 A can of freeze-off might help. I've found it works better than PB when axles are stuck. It's going to take a lot of patience but the air hammer should be a huge help. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 21, 2017 Moderators Share Posted December 21, 2017 remove the pin that holds the axle into the transmission/differential housing 4:00 into it He said that it's stuck in the hub, not the transmission. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 21, 2017 Share Posted December 21, 2017 well in that case get out big nasty and put a little hammer action on it. Link to comment Share on other sites More sharing options...
lockmedic Posted December 21, 2017 Share Posted December 21, 2017 I've had a couple of yankee cars that the axle would absolutely not come out of the hub, even on a hydraulic press. Threw the whole spindle and axle out. Rust sucks. Link to comment Share on other sites More sharing options...
eagleeye Posted December 21, 2017 Share Posted December 21, 2017 I've had a couple of yankee cars that the axle would absolutely not come out of the hub, even on a hydraulic press. Threw the whole spindle and axle out. Rust sucks. waste not = want not you all don't have a fancy parts washing basin or a big 10 gallon pail? they make pb blaster in single gallons / 5 gallon pails. I guess you could have also used some kerosene in a pail too. Link to comment Share on other sites More sharing options...
Sololeggy Posted December 21, 2017 Author Share Posted December 21, 2017 Go get a puller from local auto store, some of them will rent it to you. Tighten the puller, then hit the drive screw with a hammer. As it loosens, continue to tighten and hit with hammer. It will come out. Anti-seize the splines of the new axle to prevent it from getting stuck again in the future.Done it and it's just frozen in the hub did almost everything I could and was a waste of $200 for the axle pulled Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Sololeggy Posted December 21, 2017 Author Share Posted December 21, 2017 well in that case get out big nasty and put a little hammer action on it.I've been and spent over half an hour smacking it and I'm destroying the end of the axle more then I'm moving it Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Sololeggy Posted December 21, 2017 Author Share Posted December 21, 2017 remove the pin that holds the axle into the transmission/differential housing 4:00 into itI cut the axle in half so I could pull the trans out and worry about getting it out layer so no trans is in the car Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 22, 2017 Moderators Share Posted December 22, 2017 Considering you've gotten to the point that you cut the damn axle in half, maybe just buy a new hub and be done "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sololeggy Posted December 22, 2017 Author Share Posted December 22, 2017 Considering you've gotten to the point that you cut the damn axle in half, maybe just buy a new hub and be done [emoji38]Think that's my easiest bet or u think I can get the axle out in some how way shape or form?? Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
lockmedic Posted December 22, 2017 Share Posted December 22, 2017 waste not = want not you all don't have a fancy parts washing basin or a big 10 gallon pail? they make pb blaster in single gallons / 5 gallon pails. I guess you could have also used some kerosene in a pail too. nope. I think you're thinking of your local mechanics who are more accustomed to working on rustbuckets. I still curse and swear and have scrapped whole cars because of rust. I would make a lousy yankee. Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 23, 2017 Share Posted December 23, 2017 Sledge hammer! if that doesn't work go to the junk yard and grab a hub Link to comment Share on other sites More sharing options...
ehsnils Posted December 24, 2017 Share Posted December 24, 2017 Whenever hammering on the hub - disconnect from the gearbox first so you don't damage the bearing in the gearbox. Broken gearbox bearings sucks, hub bearings aren't a big deal. Link to comment Share on other sites More sharing options...
Sololeggy Posted December 27, 2017 Author Share Posted December 27, 2017 Whenever hammering on the hub - disconnect from the gearbox first so you don't damage the bearing in the gearbox. Broken gearbox bearings sucks, hub bearings aren't a big deal.There is no trans and the axle was cut in half Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Sololeggy Posted December 27, 2017 Author Share Posted December 27, 2017 Sledge hammer! if that doesn't work go to the junk yard and grab a hubTrying not to destroy my studs I already destroyed one, just pain in the ass to replace Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted December 28, 2017 Share Posted December 28, 2017 Freeze-off and a bfh. If you don't mind replacing the bearing, you can torch the hub or try breaking it free with a hub puller. Since the axle is cut, find a local shop that has a press and see if they can get it out. Link to comment Share on other sites More sharing options...
