Wet Cat Posted November 30, 2017 Share Posted November 30, 2017 Hello all. I very new to Subarus. I trying to help my son. He has a 1994 legacy front wheel drive only 4cyl wagon MT. He is stranded in OR in a small town. What year range and makes could he use to replace the trans with? I checked my local ( Cheyenne,Wy) jy and they are either awd or Auto Trans. I don't think so but would a mt awd work and seal off where the drive shaft exits? Also, what is this trans called? (number/letter) What engine wouls it have and what is it called so I can search on the site? For future reference, what engine size and other models will interchange for water pumps, alternator, breaks, suspension ( stock not performance)? He drove it from NY to OR back in August and is trying to get back to Michigan then NY in the next 45-60 days. Thanks in advance for any help. Pointing to other post will be helpful also. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 30, 2017 Share Posted November 30, 2017 http://car-part.com/cgi-bin/search.cgi check the zip code, I had to use mine. http://car-part.com 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wet Cat Posted December 1, 2017 Author Share Posted December 1, 2017 I see referenced throughout the site that people refer to the engine by numeric/alpha numbers and not just the engine size. How/where do I find what "engine number" and transmission number we have? I want these so I can search on this site better. Link to comment Share on other sites More sharing options...
RustyRuu Posted December 1, 2017 Share Posted December 1, 2017 transmisson code is on the driver side bellhouse by the starter it should be a white sticker. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2017 Share Posted December 1, 2017 http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html You should be able to get the service manual there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
