lucasoil4u Posted January 16, 2018 Share Posted January 16, 2018 Do a new coyote motor in there. Do something different. Link to comment Share on other sites More sharing options...
05GT Guru Posted January 16, 2018 Share Posted January 16, 2018 It's definitely different. It would be more expensive as any motor that hasn't been done before will not have a conversion kit or hybrid harnesses for sale. Mod motors also tend to be wider than a pushrod v8 because of the huge heads ... although in my f150s engine bay the 5.0 looks small. He's already got a supra motor. I say push 700+whp and see how that 240sx chassis likes it. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted January 18, 2018 Author Share Posted January 18, 2018 buddy of mine is building an s13 with an LS9 and T56. Gonna be a freakin monster when its done. Cammed, ported blower, Nitrous, i'm thinking well over 1000hp. Good luck with your build That sounds like it will be an animal! And thanks. It's definitely different. It would be more expensive as any motor that hasn't been done before will not have a conversion kit or hybrid harnesses for sale. Mod motors also tend to be wider than a pushrod v8 because of the huge heads ... although in my f150s engine bay the 5.0 looks small. He's already got a supra motor. I say push 700+whp and see how that 240sx chassis likes it. Yup that's correct, I have a 2JZ although it's out of an Arista due to needing it to be a front sump oil pan to work in the s-chassis. While the engine is capable of 700+ HP, I am really not chasing high HP numbers and realistically would like it around 400-450 as even that is going to be a lot to learn to drift with. My plan at this point is to do a single turbo since the engine doesn't have the stock twins already and do some upgraded injectors with a standalone for the initial build and after a season or so on that setup if I need more power look to build/refresh the engine. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted January 30, 2018 Author Share Posted January 30, 2018 Spent the better part of 3 days pulling the remaining interior pieces, removing all sound deadening and stripping the seam sealer in preparation for the cage fab work this week. But she's ready to go, here's a video of the process: Also picked up a Koyorad N-Flow radiator/fans, a huge FMIC, and engine mounts to place the engine in to mock up the removable core support and tubed fenders. Link to comment Share on other sites More sharing options...
Mikey B Posted February 6, 2018 Share Posted February 6, 2018 I would like to see a coyote swap in one of these, but im not sure about size restraints due to it being a DOHC vehicle. Ive got a 1uz 86 in my garage, almost finished with. Link to comment Share on other sites More sharing options...
