Infinity Posted November 1, 2017 Share Posted November 1, 2017 Hi! So after some heavy research, I still cannot get it working. I found a wiring diagram for the 05 LGT. The following goes. B134 Pin 34, That tells the car wether its auto or manual. Which you just ground it to tell it its manual. B137 Pin 9 is the neutral switch. Auto looks for 0v's in neutral, Manual looks for 12v in neutral. Clutch switch is B134 pin 1. My ECU, Doesnt have wiring in Pin 34. Which tells me, That the rest are wrong. Even after testing them like it would be if its was converted. Would anyone be able to guide me in the right direction? Maybe if someone has the correct PCM Wiring Diagram. Thank you! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2017 Share Posted November 1, 2017 Is there any link near the current date in this thread, seem to recall someone figure some things out a few months to a year back. http://legacygt.com/forums/showthread.php/6mt-master-swap-thread-107137.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infinity Posted November 1, 2017 Author Share Posted November 1, 2017 That was the thread i was browsing and found all that information on.. Link to comment Share on other sites More sharing options...
