2005 Legacy GT Camber Curves
covertrussian
Measured the camber curve of the stock struts/springs on my 05 LGT, camber bolt was maxed out for max negative camber (not that it matters). Only suspension mod is lower control arm rearward caster bushings (also shouldn't matter unless the wheel is turned).
I removed the spring, then used a digital angle gauge, which I reset to 0 when the hub was at the static height (as it would be on the ground). Then I moved the suspension from full droop to full dump and measured the camber about every 10mm.
http://legacygt.com/forums/attachment.php?attachmentid=257460&stc=1&d=1509424462
Here is the suspension at full bump (~2.4"), this is physically impossible with a spring in place. 1.60" is about the maximum realistic bump travel.
http://legacygt.com/forums/attachment.php?attachmentid=257461&stc=1&d=1509424462
CGain = Camber Gain, what this means is, this is how much camber will be gained over your static camber, add the two together to get the total camber.
Positive Travel = Bump - Upward Travel/Compression of suspension
Negative Travel = Droop - Downward Travel suspension
CGain	Travel in.
1.85	-2.72
1.55	-2.32
1.25	-1.97
1	-1.57
0.85	-1.18
0.5	-0.75
0.3	-0.35
0	0
0	0.39
-0.3	0.79
-0.4	1.22
-0.65	1.57
-0.85	2.01
-1.1	2.4
Here is that data graphed out
http://legacygt.com/forums/attachment.php?attachmentid=257464&stc=1&d=1509425946
Making sense of the data
We really only care about the positive travel (suspension compressing in a turn), since this is representative of the outside wheel in a corner. With stock suspension, the camber curve is fairly lazy (optimally you want .5-1* camber gain per 1" compression), but even then it didn't turn into positive camber like a lot of McPherson suspensions tend to.
05 LGT 16G 14psi 290whp/30mpg (SOLD)
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
22 Ascent STOCK
