Infosecdad Posted November 11, 2017 Share Posted November 11, 2017 If you continue this approach to problem solving, you'll save a ton of money by taking it to a shop. That's IF he can find a shop that does a proper diagnosis. I've had too many shops that fix by part replacement roulette. legacyGT#1, at this point you really need to invest in the ability to log the engine parameters/sensors. ODB2 Bluetooth or WIFI dongle or USB cable and software (btSSM or others) that lets you read the output, will help you understand what specifically is contributing to your problem. Link to comment Share on other sites More sharing options...
relative4 Posted November 11, 2017 Share Posted November 11, 2017 Oh, and what brand MAF did you buy? If it's not a Denso, put back the original. Link to comment Share on other sites More sharing options...
Ironworker613 Posted November 16, 2017 Share Posted November 16, 2017 Plus 1 on relative's maf brand, it's a 80/20 gamble on a non OEM maf sensor! Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 3, 2017 Author Share Posted December 3, 2017 Just an update guys, I finally got the correct MAF sensor. Turns out rockauto and amazon stock sensors are the wrong ones and you have to ordetermine the one for a turbo forester. The car now idols great but after driving for about 10 min while engaging the turbo car started running bad and was smoking under the hood and popping through the intake. So I checked under the hood and the EGT bung was glowing red and the uppipe was barely glowing so I decided to replace it with the Invidia uppipe seeing as the pre-cat was probably clogged up and these are infamous for doing so, I was gonna replace it anyways. Any other suggestions would be great thanks for all you git's help and input. Link to comment Share on other sites More sharing options...
aj_mariner Posted December 3, 2017 Share Posted December 3, 2017 Not to misdirect, but excessive exhaust heat/temp at similar engine load is from being too lean. Easy example of this is an oxyacetylene torch. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 4, 2017 Share Posted December 4, 2017 Another side note. I had my catted uppipe glow red once due to a cylinder misfire. The injector was not seating properly and was dumping fuel. Link to comment Share on other sites More sharing options...
aj_mariner Posted December 4, 2017 Share Posted December 4, 2017 Afterburners Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 4, 2017 Author Share Posted December 4, 2017 Thanks aj and bon for the info, def not a misdirection I'm just trying to fix this car on my own may be stubborn but oh well. I have a second car to drive. The car is paid for and I plan on keeping this car forever. These legacy's only have internal fuel filters, correct? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 4, 2017 Share Posted December 4, 2017 Yes fuel filter is at the bottom of the in tank fuel pump. Check out the thread about fuel pump replacement in the DIY forum under Performance Mods. It's easy to find, there are pictures there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 5, 2017 Author Share Posted December 5, 2017 Well, what do you know. Firing yet another random part at it didn't work. Actually changing out the MAF fixed my rough idle problem so it did. I don't claim to be some great mechanic but I have built a few motors, just not Subaru's. If you continue this approach to problem solving, you'll save a ton of money by taking it to a shop. I don't have a local subaru mechanic so I would rather figure it out on my own. If you're not here to help don't waste your time or mine, thanks. Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 5, 2017 Author Share Posted December 5, 2017 I thought that was the case, thanks max. That's what I think might be my issue is either the filter or the pump. Reason why is the car was running great before it started having the rough idle in gear. When in park or neutral it idles great until put under a load. Anyone know of a way to check fuel pump output psi? Obviously I would be systematic about checking a fueling issue ex (injectors, fuel pressure regulator, fuel pump and filter). Reason why I think that is because I was driving the car when the car started running rough. Link to comment Share on other sites More sharing options...
Infosecdad Posted December 5, 2017 Share Posted December 5, 2017 How it is running after replacing the up-pipe and reseting the ECU? Link to comment Share on other sites More sharing options...
relative4 Posted December 5, 2017 Share Posted December 5, 2017 Actually changing out the MAF fixed my rough idle problem so it did. If you think running it so rich you turn your cat red hot is fixing it, then you have an expensive surprise coming. If you're not here to help don't waste your time or mine, thanks. Like several others, I offered helpful advice which you ignored in favor of the parts cannon. You even went so far as deleting it when quoting me above. Obviously that was wasting my time and yours. I will no longer do so, but I will respectfully request that you post pics of the aftermath. Link to comment Share on other sites More sharing options...
aj_mariner Posted December 5, 2017 Share Posted December 5, 2017 Does it run better in hot weather, cold weather?? Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 6, 2017 Author Share Posted December 6, 2017 The car idles better. That is all im not driving it, it's parked I'm sorry man not trying to argue just stating a fact. I havent deleted any of your comments they are all on page 1 & 2. My budget only allows for about $100 for parts a month and i wanted to try and fix it asap. Which didnt work. Car is running lean not rich that is why I believe the pipe got hot but again I'm just a back yard mechanic. That is why I asked for help. Im sorry infosecdad, I mistyped, I haven't changed the up pipe just yet that will be in the coming weeks just had surgery, but as soon as I do I will let you know. Link to comment Share on other sites More sharing options...
legacyGT11657616079 Posted December 6, 2017 Author Share Posted December 6, 2017 Before it broke down it was a cold natured car aj. Link to comment Share on other sites More sharing options...
aj_mariner Posted December 7, 2017 Share Posted December 7, 2017 I don’t like the pool I’m in, but it seems like we might have a problem that is fairly common...yet hard to pinpoint. Good luck...I’m going at it myself but with a slight difference. Mine is http://legacygt.com/forums/showthread.php/4-misfire-266382.html?t=266382&highlight=Throttle+body http://legacygt.com/forums/showthread.php/low-rpm-stutter-hesitation-191993.html?highlight=Throttle+body http://legacygt.com/forums/showthread.php/just-another-misfire-rough-idle-thread-235633.html?t=235633&highlight=Throttle+body Link to comment Share on other sites More sharing options...
