urdrwho Posted September 13, 2017 Share Posted September 13, 2017 Anybody ever have a fuel line tear like this? Last year I have my 97 Outback with the transplanted 2.2 engine to my son. On Monday I get a call from him that he was on the way to work and a fluid whose smell he doesn't recognize has / is making a mess under the hood. I arrive and what I was smelling was gas. Had him start the engine and there I saw gas squirting from the fuel line that enters the fuel filter. I am 64 years old, I've owned cars since I was 16 and have never ever had a fuel line burst. Looking closer the tear is so thin it is as though a razor utility knife cut it. It was @ 30,000 miles ago that I installed a new fuel filter. I could swear that I also installed a new fuel line at that time. The fuel line that had the tear looked good, it wasn't hard and brittle, etc. but I don't see a replacement on my maintenance spreadsheet. Sometimes if it is a little replacement I forget to put it on the sheet. One thing I am positive of is that it was not the original fuel line. I replaced the fuel filter plus fuel line and he was good to go. It was a very, very odd thing and spraying gas under the hood on a running engine isn't good. The fuel vapor is what will ignite. He was lucky that he wasn't on the highway in traffic going 65 MPH without a way to quickly pull off the road. Link to comment Share on other sites More sharing options...
Setnev Posted September 13, 2017 Share Posted September 13, 2017 If you replaced that line, was it rated for fuel? I have heard of failures like this on lines that aren't rated for oil and fuel. Link to comment Share on other sites More sharing options...
urdrwho Posted September 14, 2017 Author Share Posted September 14, 2017 The writing on the hose was still clear and it said fuel injector. If you replaced that line, was it rated for fuel? I have heard of failures like this on lines that aren't rated for oil and fuel. Link to comment Share on other sites More sharing options...
doublechaz Posted September 14, 2017 Share Posted September 14, 2017 Well, #3 kills my question of was it rated for *high pressure* fuel. I put new fuel lines on mine a couple years ago during a big refresh. Those lines are not as good as the factory lines that lasted 20 years. I expect the new lines to die in one or two more years. Even though they are HPFuel rated. I blame the Mongol hordes. Link to comment Share on other sites More sharing options...
urdrwho Posted September 14, 2017 Author Share Posted September 14, 2017 The fuel line coming out of the fuel filter are original. They seem to be a much better hose than the replacements available at the parts store. Ha ha !!! "I blame the Mongol hordes." Well, #3 kills my question of was it rated for *high pressure* fuel. I put new fuel lines on mine a couple years ago during a big refresh. Those lines are not as good as the factory lines that lasted 20 years. I expect the new lines to die in one or two more years. Even though they are HPFuel rated. I blame the Mongol hordes. Link to comment Share on other sites More sharing options...
