raider600 Posted September 3, 2017 Share Posted September 3, 2017 The other day I was shifting out of park, pressed the brake and heard a click. It doesn't click when I'm driving or slowing down as others have experienced. It only does it when pressing the brake while in park. Video of actual piece making noise https://drive.google.com/file/d/0BydFO6Iz7T75ZUZqZ0FTbS1qT2M/view?usp=sharing Pictures. https://imgur.com/isN2hBD https://imgur.com/78IIUBZ Solenoid part # (I think) - 35173AJ001 How can I replace this part? Do I have to remove those 4 bolts in each corner of the shift assembly? Can I just loosen them and slide this out? Link to comment Share on other sites More sharing options...
t0lkman Posted September 22, 2017 Share Posted September 22, 2017 How have you ended up fixing it? I have the same problem Link to comment Share on other sites More sharing options...
raider600 Posted January 4, 2018 Author Share Posted January 4, 2018 How have you ended up fixing it? I have the same problem It eventually went away. Hasn't happened since. Link to comment Share on other sites More sharing options...
t0lkman Posted January 5, 2018 Share Posted January 5, 2018 I removed led bulbs from brake lights and my issue also gone Link to comment Share on other sites More sharing options...
Wambulator Posted April 9, 2018 Share Posted April 9, 2018 I removed led bulbs from brake lights and my issue also gone Interesting. I'll give that a try. I put in led's too. That's about the same time my shift inter-lock started clicking. Just when in idling in"P" position...repeatedly clicking like it's confused. Would the shift inter-lock solenoid be covered under 60k powertrain warranty?...I have less than 100 miles until 60k. Update: It is considered a normal wear and tear part...not covered under warranty. Link to comment Share on other sites More sharing options...
Bootyologist Posted April 18, 2018 Share Posted April 18, 2018 Interesting. I'll give that a try. I put in led's too. That's about the same time my shift inter-lock started clicking. Just when in idling in"P" position...repeatedly clicking like it's confused. Would the shift inter-lock solenoid be covered under 60k powertrain warranty?...I have less than 100 miles until 60k. Update: It is considered a normal wear and tear part...not covered under warranty.it's definitely the LEDs. many of us with early model 5th gens have had the issue. Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
