Jimmye212 Posted August 31, 2017 Share Posted August 31, 2017 Hello, I have a 2009 LGT and I cracked the plastic housing of the TGV motor on the passenger side. I was trying to find a part number, but only found one for the 05/06 LGT (14120AA060). For a 2009, I only saw the motor as part of the whole TGV assembly. I am basically wondering what my options are here. Will I be able to still use my TGV motor if I glue the casing back together? I will upload a picture. Can I get the motor for the 05/06? Or should I simply get the IAG TGV deletes and call it a day? I will be getting a tune after this, so that is not an issue. Thanks! Link to comment Share on other sites More sharing options...
vbwstripes Posted August 31, 2017 Share Posted August 31, 2017 That's just the connector piece right? Can you plug it in and see if it still functions correctly? Maybe delete time. Link to comment Share on other sites More sharing options...
Jimmye212 Posted August 31, 2017 Author Share Posted August 31, 2017 Yeah it's only the connector piece. Unfortunately I can't plug it in to test it right now since I'm in the middle of a rebuild. Would I be better off getting the IAG deletes (~$300) or just doing it myself? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2017 Share Posted August 31, 2017 Your tuner can delete the CEL for the code if your tgv's still work. I have a broken sensor on the passenger side, my tuner just deleted it from the CEL. Car drives great. In this thread may have some info. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
