Whopper Posted August 27, 2017 Share Posted August 27, 2017 Im posting this thread in both First and Second Gen. Hello I was wondering If anyone could confirm this to be a good parts list for an engine rebuild. Pistons JE 97.5mm Main and Rod Journal size Id keep standard with a phase one 75mm crankshaft Manley Turbo Tuff connecting rods new 11mm head studs STI OEM oil pump .030 head gasket ej20 heads for better flow gates timing belt kit for ej20 heads New harmonic balancer AEM stand alone ECU I also want a new exhaust system along with a wrx or a sti aftermarket turbo Please tell me if any of theis parts will go through my engine I dont plan on using its full power with all of this but I want it to be their for track days ever once in a while. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 28, 2017 Share Posted August 28, 2017 http://legacygt.com/forums/showthread.php/finally-got-cryotuned-youi-194437.html You should contact Dave at Cryoperformance for the right answers. See post #3 in that thread. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
