Andrew1707 Posted August 16, 2017 Share Posted August 16, 2017 Recently changed t belt, water pump with Dayco kit. Ran fine for 2 weeks. While accelerating onto highway got the blinking CE misfire light. Codes for cylinders 1 and 3. I'm ASSUMING the Dayco tensioner failed. Bought a new OEM tensioner, will replace this week end. My question is, if in fact my timing is off by a tooth or two, will this cause damage if I continue driving on a daily basis? Car runs fine accept for slighty slower acceleration, I did change all plugs, wires, and coil with OEM parts. Misfire code still showing. Thanks in advance for Any info. Link to comment Share on other sites More sharing options...
MilesA Posted August 16, 2017 Share Posted August 16, 2017 Too many assumptions, I'm afraid. You can safely be off by one tooth, but what happens if it slips again? Then you could be in trouble. Also, maybe the problem lies elsewhere. Link to comment Share on other sites More sharing options...
Andrew1707 Posted August 17, 2017 Author Share Posted August 17, 2017 I hear you, but don't see the misfires being a coincidence 2 weeks after changing the belt. Forgot to mention I also replaced the crank pulley with a Perrin lightweight pulley. Heard of codes being thrown using these too. Link to comment Share on other sites More sharing options...
MilesA Posted August 17, 2017 Share Posted August 17, 2017 I hear you, but don't see the misfires being a coincidence 2 weeks after changing the belt. Forgot to mention I also replaced the crank pulley with a Perrin lightweight pulley. Heard of codes being thrown using these too.Did your car have the timing belt guides over the crankshaft and the cams? If so, did you adjust those to the right clearance? Link to comment Share on other sites More sharing options...
Andrew1707 Posted August 17, 2017 Author Share Posted August 17, 2017 No only manuals have the guide, mines auto. Link to comment Share on other sites More sharing options...
apexi Posted August 17, 2017 Share Posted August 17, 2017 Our manuals still have 1 guide over the crank Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 17, 2017 Share Posted August 17, 2017 No only manuals have the guide, mines auto. I believe the auto still have guides on the sides of the timing belt covers still. but no guide over the crank pulley. Proper clearance of these suckers is key. Link to comment Share on other sites More sharing options...
apexi Posted August 17, 2017 Share Posted August 17, 2017 Whoops... Totally misread what you said earlier. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 17, 2017 Share Posted August 17, 2017 And yeah. I believe that timing must be off if the timing belt was just worked on AND misfires are occurring only one side of the engine. Also, fyi, the manual says if off by more than 3 teeth, valves will hit the pistons. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 19, 2017 Share Posted August 19, 2017 Redo the timing, put the stock crank pulley back on. Why would you even fathom driving with a condition that could lead to catastrophic failure when two hours checking over your work could prevent it ? On an EJ you don't want to deal with rebuilds until you are forced to:) Link to comment Share on other sites More sharing options...
