d22597 Posted August 7, 2017 Share Posted August 7, 2017 Recently had a shop install a new clutch in my 09 specb and noticed some rattling at the bell housing. Further inspection I found the housing cover is only attached on the drivers side and chewed up on the pass side. Looks like it made contact with the flywheel at some point and now just rattling loose. Any thoughts on what caused this and best course of action? I keep finding more things the shop screwed up and nervous what else they messed up. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2017 Share Posted August 7, 2017 I would not start the engine again until that is fixed. Flat bed the car to the shop and have them fix what they screwed up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
d22597 Posted August 8, 2017 Author Share Posted August 8, 2017 No way I'm letting them touch my car again. I just installed all new suspension components, turbo, tmic, fueling, etc. Is it possible to replace the cover without removing the trans? Here is a partial list of what I found from the review I wrote. Since, I also found the pitch arm loose and other missing bolts. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 8, 2017 Share Posted August 8, 2017 Is it possible to replace the cover without removing the trans? Are you referring to the pressure plate? If yes, then you have to drop the trans in order to access it. Link to comment Share on other sites More sharing options...
d22597 Posted August 8, 2017 Author Share Posted August 8, 2017 The part is a small cover that bolts on the bottom of the engine. The part is called "clutch housing cover". This is the best illustration I could find. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 9, 2017 Share Posted August 9, 2017 Remove that cover. Mine has been in the shed for about 6 years now. Some day I might put it back on...yea, right. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 9, 2017 Share Posted August 9, 2017 ^ Link to comment Share on other sites More sharing options...
d22597 Posted August 13, 2017 Author Share Posted August 13, 2017 Got the cover off. It wasn't easy and had to use tin snips to take it out in pieces. Also looks like a chunk of the block was damaged. I'm wondering if the shop dropped a bolt or something in the clutch housing, got caught in the flywheel, then ejected through the cover? The cover bolt was still in the right side with a small section of the cover still bolted to the block. Unfortunately, it's hard to tell the damage to the cover by me getting it out vs what happened on its own. Link to comment Share on other sites More sharing options...
d22597 Posted August 13, 2017 Author Share Posted August 13, 2017 Mystery solved. After I posted above, I remembered I had USB endoscope camera and did some more exploring. Looks pretty obvious the shop pinched a corner of the cover between the trans and motor. There is still a small piece left sandwiched. I'm guessing I will need to loosen the trans from the block to get the last of the cover. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 13, 2017 Share Posted August 13, 2017 Nice troubleshooting. But this sucks man. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 15, 2017 Share Posted August 15, 2017 And the shop didn't notice any noise when they started the car... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
