H2OSB Posted July 24, 2017 Share Posted July 24, 2017 Can someone please tell me the part number of the VF40 oil drain hose or what ever kind of tubing I can replace it with? I killed my turbo and am in the process of replacing it. While man-handling the old turbo, after getting it out, I cracked the rubber hose that drops straight down from the turbo to the engine. I am only assuming it's the oil return hose. I'm not 100% certain. All I know is it cracked just below the metal tube portion of the bolt on flange it slides onto. Thanks in advance H2OSB Link to comment Share on other sites More sharing options...
MilesA Posted July 24, 2017 Share Posted July 24, 2017 They get brittle with age. OEM Turbo Drain Hose = P/N 807515712 OEM Turbo Drain Hose Clamp, Upper = P/N 805922090 OEM Turbo Drain Hose Clamp, Lower = P/N 805922080 http://opposedforces.com/parts/legacy/us_b13/type_5/intake_and_supply_system_turbocharger/turbo_charger/ Link to comment Share on other sites More sharing options...
Max Capacity Posted July 24, 2017 Share Posted July 24, 2017 Some say you can get a oil resistant hose from the auto parts store... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted July 25, 2017 Share Posted July 25, 2017 Some say you can get a oil resistant hose from the auto parts store... Yup, this is what I did, it will save you time and money. Just take in the remaining hose to your local auto part store and have them match it up to another oil feed hose (1 foot, cut to fit), you'll be good to go. Make sure to buy new clamps too. Cost me about $5.00 for hose and clamps. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
