journey Posted December 14, 2018 Share Posted December 14, 2018 Mine doesn’t sit low imo. Aside from it not being perfectly centered ... 2hrs messing with it. The Y-pipe will sit a touch lower just due to size but not much. ... I did not need to cut the heat shield at the midpipe. I actually checked and could stick a finger between midpipe and heat shield Did you get some poly hangers? The Perrin ones r really nice. I’ve gotten them for all my cars. They’ll help keep it a little tighter up as well Good luck with the install Thanks for the heads up on the heat shield and on the exhaust not being quite centered -- I am OCD enough that I would have spent way too much time figuring it out. Will be interesting to see if the 2009 sedan will be the same as the 2005 wagon. I picked up an exhaust donut and a set of the following from Subimods: Grimmspeed 12MM Two Position Exhaust Hanger -- not sure if the two position hanger is a gimmic, but it seemed reasonable when I was ordering just before Thanksgiving. Hopefully, re-using the bolts that connect the DP to the MP will be an option -- if not, I will be be making a run to a nearby auto-parts store on Sat AM (assuming it is not raining). The HKS was on back-order from Japan, and I was not expecting it to arrive in the US until Jan. I was pleasantly surprised when it arrived after only 2.5 weeks. ;-) Ended up replacing the timing belt & rear rotors last week, so the DP will not be in my future anytime soon... Link to comment Share on other sites More sharing options...
Wooosh Posted December 14, 2018 Share Posted December 14, 2018 Hopefully, re-using the bolts that connect the DP to the MP will be an option -- if not, I will be be making a run to a nearby auto-parts store on Sat AM (assuming it is not raining). I went to my local hardware store n got 2 sets of 2” M6 Stainless bolts (1 1/2” would suffice in hindsight), nuts, washers n locks. U may not necessarily need them but I found it easier just to cut my old ones and use new. Also had to ream out the OEM DP holes for those so a good bit may be in order as well. Good luck Link to comment Share on other sites More sharing options...
