mudfoot Posted October 23, 2005 Share Posted October 23, 2005 Installing the Goodridge SS brake lines are smooth until you have to put those dam clips back.... :eek:Pain in th *ss... Carbotech pads.. went on with no problems, and they worked very well in the down pour on I87 tonight. Before I installed the pads i used some sand paper on the rotor and I did the bedding proccess in the rain going from 60 to 30 about eight times.. I also installed my perrin crank pulley today. that went pretty smoth as well.... Time to rest... Its not alot of fun to do all this work in a garage\barn when its cold and raining outside. But at least I didnt get too wet during the process... Got Torque ? Link to comment Share on other sites More sharing options...
skubdu Posted October 24, 2005 Share Posted October 24, 2005 what brake fluid did you use? and how did you bleed your brakes? Link to comment Share on other sites More sharing options...
mudfoot Posted October 24, 2005 Author Share Posted October 24, 2005 i used motul rbf600 brake fluid and i started bleeding from the rear passenger side then the rear drivers too passenger front then the drivers side. As it was draining i would add new fluid, and i did this one full bottle and 3\4 of another. Got Torque ? Link to comment Share on other sites More sharing options...
skubdu Posted October 24, 2005 Share Posted October 24, 2005 cool thanks, i will be doing the SS lines this weekend hopefully results will be good. Link to comment Share on other sites More sharing options...
mudfoot Posted October 24, 2005 Author Share Posted October 24, 2005 i think the brake pedal feels a little fimer.. but to me the biggest difference is the carbotech brake pads...i hope you dont have the problems i had with the clips for the brake lines Got Torque ? Link to comment Share on other sites More sharing options...
Th3Franz Posted October 24, 2005 Share Posted October 24, 2005 The clips are a PITA... just take your time. The first set is the hardest and then the rest go much faster once you figure it out. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
