tom_kauf Posted June 29, 2017 Share Posted June 29, 2017 Hi everyone, Tom here from the Australian Forums. I hope someone can help me, I've searched everywhere and had no luck. Does anyone know where the factory O2 sensor relay is located? I don't know if some things are mirror-imaged on our right-hand-drive cars. But the Parts Diagram says it is supposed to be here (top position of the relay stack on the LH side): http://i64.tinypic.com/3534jfb.jpg But when I check there, that position is blank (no connector or any wiring there at all). I don't see any relay of that size on RH side either. http://i65.tinypic.com/23k27uu.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 Have you searched youtube or asked google ? BTW, I'm so jealous...SpecB wagon, lucky you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tom_kauf Posted June 30, 2017 Author Share Posted June 30, 2017 Have you searched youtube or asked google ? BTW, I'm so jealous...SpecB wagon, lucky you. Yeah, I've spent many hours doing research. Different things come up, but very little for Gen4 Legacys/Libertys. I have the Service Manual as well, and looked at all the relevant wiring diagrams, and connector locations. This has led me to where I found this relay bank. But it's blank And thank you, it's a keeper Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 So your's was never there ? Is there a problem ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tom_kauf Posted June 30, 2017 Author Share Posted June 30, 2017 I've burnt out my Innovate Motorsport Wideband O2 Sensor in less than 9months, probably because of shock cooling. This seems to be very common unfortunately. See below for a very interesting article on why these Bosch sensors last 60,000miles+ in stock applications, but fail much quicker in aftermarket installs. I had the relay control wire hooked up to the Ignition, but that was only because I couldn't find any circuit that only got power with the engine running. So now I'm looking to wire it up the factory O2 relay control wire. *Why Bosch Wide-band air/fuel ratio sensors fail so often in aftermarket applications* And yeah, the car runs fine and was stock when I bought it. So no one has removed anything as far as I know. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 While reading that, I remembered we had short life out those in the race car over 10 years back. Just had a thought, what does the STi use for controlling the heater on the O2 ? Is there any possibility researching that could help ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tom_kauf Posted July 1, 2017 Author Share Posted July 1, 2017 Ah ok, interesting. They probably use a Relay like most cars. But it'll be in a different location, so it may not help with finding ours. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 1, 2017 Share Posted July 1, 2017 Sorry I can't be more help. You may try a PM to m sprank, or his web site is http://www.infamouperformance.net he's in Calif. and has a real repair shop, he may have some thought's. Years ago I talked with Paul at AVO World parts You have luck here, https://www.google.com/search?q=avo+turboworld+australia&oq=AVO+world&aqs=chrome.4.69i57j0l5.14394j0j8&sourceid=chrome&ie=UTF-8 Ask them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tom_kauf Posted July 1, 2017 Author Share Posted July 1, 2017 That's ok, thank you for the advice though. Ok, cool - I'll see how I go this weekend and contact some businesses on Monday if I don't have any luck . Link to comment Share on other sites More sharing options...
