Scottydunno Posted June 27, 2017 Share Posted June 27, 2017 As the title says... its weird. AC blows cold, then slowly gets warm, then cycles to cold again. While its doing this cycle the fan speed slows down when getting warmer then speeds up when it gets cold. Overall the car does cool off just does this weird cycling thing. The car is an 05 LGT with auto climate. Link to comment Share on other sites More sharing options...
MilesA Posted June 27, 2017 Share Posted June 27, 2017 How frequently does the A/C get warm -- is it every few minutes? Or does it seem to constantly alternate between cold and warm air? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 27, 2017 Share Posted June 27, 2017 When was the AC last serviced ? It could be low on R134. I recharged mine with a can from the auto parts store. If the fan speed changes, see this. http://legacygt.com/forums/showthread.php/blower-motor-runs-slow-hot-out-261637.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted June 27, 2017 Share Posted June 27, 2017 Sometimes recharging that way works. But, if the system has gotten moisture in it, it will cause problems so the system needs to be evacuated (put under vacuum) before recharging with new refrigerant. The system does periodically cycle off then back on, though, to prevent the evaporator core from freezing up. It would be every few minutes, though, not constantly. Link to comment Share on other sites More sharing options...
Scottydunno Posted June 27, 2017 Author Share Posted June 27, 2017 How frequently does the A/C get warm -- is it every few minutes? Or does it seem to constantly alternate between cold and warm air? Anywheres as little as 30 seconds to approx 2 minutes. The longer the cycle the cooler the car is. Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted June 28, 2017 Share Posted June 28, 2017 Sounds like you are low on refrigerant and it's causing the compressor clutch to frequently cycle off and on. Link to comment Share on other sites More sharing options...
Scottydunno Posted June 28, 2017 Author Share Posted June 28, 2017 When was the AC last serviced ? It could be low on R134. I recharged mine with a can from the auto parts store. If the fan speed changes, see this. http://legacygt.com/forums/showthread.php/blower-motor-runs-slow-hot-out-261637.html I've had the car since January. No known history of the AC. It had a noisy blower motor to begin with, hence how I knew the fan speed changing with the temp. I've since changed the motor. It's nice and quiet, however it still changes speed. Maybe my problem is to-fold. A bad resistor/transistor and need a recharge. Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 I'm thinking you are correct, two fold problem. Tomorrow it's going to be hot and humid here, on the drive home I'll test my new transistor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scottydunno Posted July 2, 2017 Author Share Posted July 2, 2017 I'm thinking you are correct, two fold problem. Tomorrow it's going to be hot and humid here, on the drive home I'll test my new transistor. How did the new transistor work out? Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted July 3, 2017 Share Posted July 3, 2017 I think mine does that too, though I wouldn't say warm to cold, more like cool to cold. I brought it into subaru last summer when it happened for a recharge (@ around 200k), and it still does it after the recharge. I only really notice it when it's hot out, like today it was almost 90F here and I noticed it. I figure it's just the way things are, the AC is struggling a little because of the warmer weather. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 3, 2017 Share Posted July 3, 2017 The compressor cuts off under heavier loads. Does it change temps usually on acceleration? Link to comment Share on other sites More sharing options...
Scottydunno Posted July 4, 2017 Author Share Posted July 4, 2017 The compressor cuts off under heavier loads. Does it change temps usually on acceleration? Nope.. temp changes till the interior basically cools down, then it pretty much works as it should. Link to comment Share on other sites More sharing options...
