MilesA Posted June 28, 2017 Share Posted June 28, 2017 Are there any benefits to having colder plugs? If your current plugs really are too hot, yes. Too hot plugs could lead to pre-ignition by encouraging hot-spots in the cylinder. Pre-ignition can be extremely damaging to the motor. Too cold plugs can become fouled more easily, and can make the car harder to start, especially when the engine temperature is low (wintertime). Race cars tend to run colder plugs, since they are running flat-out all the time. So, I guess that means we should do the same with our daily driver cars since we are such extreme guys, always pushing the limits, right? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 28, 2017 Share Posted June 28, 2017 You got that right 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted June 28, 2017 Share Posted June 28, 2017 Hey, with a screen name like Max Capacity, I figure you must be an extreme kind of guy! Anyway, OP, don't overthink it, the point is there is an optimal spark plug heat range for your car and driving conditions, and you want to be in that range. There is no benefit to running cooler plugs than you actually need. Link to comment Share on other sites More sharing options...
robburns201 Posted June 29, 2017 Author Share Posted June 29, 2017 So I'm gonna just ask the mechanic to look at plugs and if they look like they are running hot then I will go colder...otherwise I'm gonna stick to stock heat range....Thanks for all the help and info.... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 In that case, he'll recommend you stay with stock heat range. Which is fine. MilesA, I have been known to push it to the redline and beyond... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
