Anthony I Posted June 22, 2017 Share Posted June 22, 2017 So I went to go start up my legacy today and I went to turn in key.It would not turn over but when I turned the key the fuel pump would turn on.At first I thought maybe dead battery so went to store to purchase one.Still no luck so I desided to bump start it since it is parked on a hill but also no luck.When i tried to bump start it it threw error code HC.Could someone tell me what this code could possible mean and how to fix this as I am really stumped.Thanks Link to comment Share on other sites More sharing options...
Infosecdad Posted June 22, 2017 Share Posted June 22, 2017 Is it the display that reads "er HC" ? Are fans cycling? Are the green connectors plugged into each other under the glove box? If so, unplug them as they are for a special diagnostic mode, and try again. Link to comment Share on other sites More sharing options...
Hirschman Posted June 22, 2017 Share Posted June 22, 2017 Could also be the main harness is loose in the engine bay, it is by the passenger strut tower. Link to comment Share on other sites More sharing options...
Anthony I Posted June 24, 2017 Author Share Posted June 24, 2017 Is it the display that reads "er HC" ? Are fans cycling? Are the green connectors plugged into each other under the glove box? If so, unplug them as they are for a special diagnostic mode, and try again. I will check but also to mention when I turn key I hear a clicking comming from glove box Area Link to comment Share on other sites More sharing options...
Anthony I Posted June 24, 2017 Author Share Posted June 24, 2017 Could also be the main harness is loose in the engine bay, it is by the passenger strut tower. Double checked that and it is tight Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2017 Share Posted June 24, 2017 http://people.csail.mit.edu/ilh/vacation/ What have you done to the car in recent day's, any thing different ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted June 24, 2017 Share Posted June 24, 2017 And has someone else been in the car? Even a kid like 7 to 10 years old that has found the green connectors and connected them? Link to comment Share on other sites More sharing options...
utc_pyro Posted June 24, 2017 Share Posted June 24, 2017 "er HC" indicates a high speed canbus error. As in the gauge cluster/BIU aren't getting counter updates from something on the bus. It sounds like ether the ECU is dead/dosent have power or something shorted the bus. Link to comment Share on other sites More sharing options...
Merc6 Posted June 25, 2017 Share Posted June 25, 2017 "er HC" indicates a high speed canbus error. As in the gauge cluster/BIU aren't getting counter updates from something on the bus. It sounds like ether the ECU is dead/doesn't have power or something shorted the bus. When my battery is going dead I was getting this. When I fried my ECU via AP V1 I also was getting this. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
