06SubLegTx Posted June 9, 2017 Share Posted June 9, 2017 Hello, I just spent a lot of money on head work because of a failed tensioner. All new Gaskets, Seals, Valves. I had the injectors cleaned and all new o-rings. The day before the tension broke I filled the car with 93 octane fuel and injection cleaner to the tank before the tensioner broke. I want to drain the old gas and injection cleaner that has been in the car for over a month and a half. I have try to get a hose down there the filler neck with no luck. Is there another way? Link to comment Share on other sites More sharing options...
KRM Posted June 9, 2017 Share Posted June 9, 2017 Remove the plastic undercover from both sides of the gas tank. There's a drain bolt just underneath them. Link to comment Share on other sites More sharing options...
Gex Posted June 9, 2017 Share Posted June 9, 2017 Month and a half? You're fine. Mine sat for 6 months with 3/4 a tank while I did my rebuild and was just fine. Modern gas takes about a year to go bad. Link to comment Share on other sites More sharing options...
Zachariahc Posted June 9, 2017 Share Posted June 9, 2017 ^Agree. Alternatively. Is it possible to disconnect a fuel line and just run the pump? Link to comment Share on other sites More sharing options...
Gex Posted June 9, 2017 Share Posted June 9, 2017 Pump will only cycle for 2 seconds with key in on position. Get maybe a cup. Needs engine rpm for more. Link to comment Share on other sites More sharing options...
apexi Posted June 9, 2017 Share Posted June 9, 2017 Interesting.. I was kind of curious about this too. Subaru told me that they had to drain half my tank (from full) when they replaced my cracked fuel pump housing, and I was wondering how I would have done that if I had done it myself. Link to comment Share on other sites More sharing options...
Zachariahc Posted June 9, 2017 Share Posted June 9, 2017 Pump will only cycle for 2 seconds with key in on position. Get maybe a cup. Needs engine rpm for more. Buuuuut. If you connect the green test connectors and put the key in the on position but don't start it. Won't the pump run continuously? I feel like I've either heard of this method or heard the pump before flashing maps. Link to comment Share on other sites More sharing options...
