tonystark0007 Posted June 4, 2017 Share Posted June 4, 2017 Hi forum just purchsed a set of spec b wheel one has a heavy scrath can i repair my self or any shop in tri state area nj ny pa that not expensive any ideas thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2017 Share Posted June 6, 2017 Yep, I have had them repaired by my local wheel repair shop. I warn you the Hyper Silver paint is not cheap. I actually need to have at least one more of my winter set touched up. Just told another guy from NJ to call Mike or Rey at http://www.AZPinstalls.com and see if they know someone. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tonystark0007 Posted June 7, 2017 Author Share Posted June 7, 2017 thanks ill contact them Link to comment Share on other sites More sharing options...
tonystark0007 Posted June 7, 2017 Author Share Posted June 7, 2017 quick question i see you own a spec 09(max capacity) how the bilstein set up feel as far as pot hole i just got a 08 spec b suspension with 45 thous miles with spring top hat oem i have on my car now jdm gt rev. b blistein sucks in pot holes Link to comment Share on other sites More sharing options...
Max Capacity Posted June 10, 2017 Share Posted June 10, 2017 I have to agree a little. There is this one dip in the pavement, my wagon sucks it up without any fuss, the Spec B hits it and make a loud bang noise. The car dose ride nice thou. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
