Winesalot Posted May 18, 2017 Share Posted May 18, 2017 Had a camshaft seal leaking so I replaced it along with an entire timing kit including water pump. I am meticulous about keeping bolts with parts. Seriously, it's a compulsion for me. But this time I have mysteriously lost the seven sleeved bolts and one standard bolt that hold the center timing cover on. I am completely baffled where they could be. Any idea where I can buy those unique bolts or what they are actually called so I can start asking Uncle Google where to buy therm? Link to comment Share on other sites More sharing options...
Winesalot Posted May 18, 2017 Author Share Posted May 18, 2017 OK, I guess I was a bit too quick to post this question. I found them on both Ebay and Amazon with a quick search. Buying new bolts is solved but the mystery of where they went will haunt for a long time. Link to comment Share on other sites More sharing options...
Whopper Posted May 19, 2017 Share Posted May 19, 2017 Did you screw them back into the holes when the cover was off? I do that to keep track of them. Link to comment Share on other sites More sharing options...
doublechaz Posted May 19, 2017 Share Posted May 19, 2017 Well, if it isn't rattling while running... Link to comment Share on other sites More sharing options...
Winesalot Posted May 19, 2017 Author Share Posted May 19, 2017 Did you screw them back into the holes when the cover was off? I do that to keep track of them. That is something I would do too but I checked and they are not there. Even had the wife go out and give the area some fresh eyes. This will cause sleep loss for me, lol. Link to comment Share on other sites More sharing options...
Setnev Posted May 19, 2017 Share Posted May 19, 2017 Ha, I am the same way. I am meticulous about putting bolts where they originally went during disassembly of anything, especially larger jobs that span weeks or months. I hate it when I see a tool in the garage, don't pick it up, and then I need it and it's not where I last saw it. I did that with my sanding block. I swore up and down it was on the shelf with all the sandpaper in my garage. Two months later, I took my SVX to a meet and opened the trunk, the MF'er was in the damn trunk the whole time. Link to comment Share on other sites More sharing options...
doublechaz Posted May 20, 2017 Share Posted May 20, 2017 I have multiple of many tools because I don't put them away and it's quicker to get another than locate the missing one. Once I have a copy of that tool for each work area the problem goes away. Link to comment Share on other sites More sharing options...
