Bassman007 Posted May 13, 2017 Share Posted May 13, 2017 How long can one drive with a faulty center differential?? Mine has been bad for a couple of months now. Runs fine on straight road, but during intricate turns I get the binding. Link to comment Share on other sites More sharing options...
BBPeik Posted May 13, 2017 Share Posted May 13, 2017 The longer it is in there the more bits of junk that will be floating around inside there. I would replace it asap. You can replace it pretty easy with the trans in the car. I have all my parts sitting around if you need any reference pics. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
dgoodhue Posted May 13, 2017 Share Posted May 13, 2017 Runs fine on straight road, but during intricate turns I get the binding. When an AWD transfer case is locked, something has to give, either the tires will slip and/or likely find the weakest link in the AWD. My AWD truck has a viscous coupler like the MT Subaru have. The VC is a sealed unit, when they lock the plates inside the VC fuse together. Because its a sealed unit it does not contaminate anything else, I imagine Subaru are the same way. The common is failure in my truck from a lock VC is broken front passenger axle or damaged front differential. Link to comment Share on other sites More sharing options...
ehsnils Posted May 13, 2017 Share Posted May 13, 2017 It's not good to drive around with a binding clutch pack, it can crack or break other parts of the transmission. Fix as soon as possible. Link to comment Share on other sites More sharing options...
