Carmania24 Posted January 31, 2019 Share Posted January 31, 2019 (edited) Getting a little off topic here. But It's a JDM motor with dual AVCS (intake and exhaust), your USDM ECU only has intake AVCS, thus exhaust AVCS is unusable, hence unplugged. Whether or not that's healthy is beyond the scope of this thread . Sorry and thanks for the help. @covertrussian call me stupid if you may, but the driver side OCV is located at the bottom of the car or on top? Edited January 31, 2019 by Carmania24 Link to comment Share on other sites More sharing options...
malimx6 Posted February 14, 2019 Share Posted February 14, 2019 how did you pry out the passenger side? I got to the point where it needed about 1.5-2cm to come out but I was afraid to damage it and also if it pops out, not being able to put it back in. Any tips on taking out the passenger side would be appreciated. Link to comment Share on other sites More sharing options...
covertrussian Posted February 14, 2019 Author Share Posted February 14, 2019 Sorry and thanks for the help. @covertrussian call me stupid if you may, but the driver side OCV is located at the bottom of the car or on top? Missed this edit. Driver side is on top too, intake vales are ontop on both halfs. how did you pry out the passenger side? I got to the point where it needed about 1.5-2cm to come out but I was afraid to damage it and also if it pops out, not being able to put it back in. Any tips on taking out the passenger side would be appreciated. Try to rotate it while pulling it out, if that doesn't work lightly tap on the metal bracket to push it out. It's screwed in and sealed with an O-ring so it should go in easily with new valve. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
malimx6 Posted February 14, 2019 Share Posted February 14, 2019 Do you mean, tap the bracket with hammer a little to push it out? It's pretty strong. I tried with a screw driver and bent it :/ Link to comment Share on other sites More sharing options...
Infosecdad Posted February 14, 2019 Share Posted February 14, 2019 Wow, when taking out my passenger side, I just had to rotate it a little bit and wiggle it at the end and it came right now. I'm curious what you are hanging up on. Link to comment Share on other sites More sharing options...
covertrussian Posted February 14, 2019 Author Share Posted February 14, 2019 I think I know what it might be, the damn banjo filter!!! Take out the banjo bolt and see if yours has the banjo filter in there, it could be stuck inside the OCV valve. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
malimx6 Posted February 15, 2019 Share Posted February 15, 2019 Wow, when taking out my passenger side, I just had to rotate it a little bit and wiggle it at the end and it came right now. I'm curious what you are hanging up on. I wiggled it and rotated and it was stuck on the coolant tank bracket/mount. Needed about 1.5-2cm more to take it out. I was afraid if I force it out, I wouldn't be able to put it back in. I am trying to swap the driver side with passenger side to see if it code will change from P0021 to P0011. Link to comment Share on other sites More sharing options...
Infosecdad Posted February 15, 2019 Share Posted February 15, 2019 I wiggled it and rotated and it was stuck on the coolant tank bracket/mount. Needed about 1.5-2cm more to take it out. I was afraid if I force it out, I wouldn't be able to put it back in. I am trying to swap the driver side with passenger side to see if it code will change from P0021 to P0011. You've unbolted the upper coolant tank so you can shift that right? Is this the bracket that's on the intake manifold? I rotated the bracket on the OCV 90 degrees toward the outside of the engine and was able to get it past with minimal leveraging. The trick for me was to pull the first valve cover hose to get enough clearance. If you have original hoses it might shatter, so may want to plan to replace it just in case. I had replaced with new hoses a month before so it went smoothly. Link to comment Share on other sites More sharing options...
malimx6 Posted February 15, 2019 Share Posted February 15, 2019 hey, thanks for the reply. Of course, took the engine cover off. Unbolted the coolant tank and pushed it to the side so it's out of the way. Unhooked that breather hose, had to do that on both sides of the engine. Pried out the OCV with screwdriver slowly, one it was out I was able to move it out with hands. Once it hits the coolant tank bracket, turned it 90 degrees. Wiggled it to the point that I could no longer move it with my hands, needed about 1.5cm more to come out. I got a blister on my finger from wiggling and pushing lol that's how tight it was. If that bracket was in like 2-3mm towards the engine, OCV would slide out easily. I might try tapping that coolant tank bracket with hammer just to gain the clearance. I'm just afraid to break it. Link to comment Share on other sites More sharing options...
Infosecdad Posted February 15, 2019 Share Posted February 15, 2019 hey, thanks for the reply. Of course, took the engine cover off. Unbolted the coolant tank and pushed it to the side so it's out of the way. Unhooked that breather hose, had to do that on both sides of the engine. Pried out the OCV with screwdriver slowly, one it was out I was able to move it out with hands. Once it hits the coolant tank bracket, turned it 90 degrees. Wiggled it to the point that I could no longer move it with my hands, needed about 1.5cm more to come out. I got a blister on my finger from wiggling and pushing lol that's how tight it was. If that bracket was in like 2-3mm towards the engine, OCV would slide out easily. I might try tapping that coolant tank bracket with hammer just to gain the clearance. I'm just afraid to break it. Which year do you have? Wondering if it's a difference in a later year or not. Link to comment Share on other sites More sharing options...
Scoobiidoo Posted February 16, 2019 Share Posted February 16, 2019 I think I know what it might be, the damn banjo filter!!! Take out the banjo bolt and see if yours has the banjo filter in there, it could be stuck inside the OCV valve. I second @covertrussian. The filter is probably wedged on the valve and stop it from turning out Link to comment Share on other sites More sharing options...
Harshjay Posted March 16, 2020 Share Posted March 16, 2020 I had stumbling idle, and a gassy exhaust smell. It may be a leaking fuel pulsation damper as well, but I have never looked at the ocv or the screens above it. Wow, what did I find, but the screens destroyed, and pieces stuck in the valve, preventing it from open/close, and holding it part way open on both oil circuits. Has Subaru ever released a service bulletin on this ridiculous fault? I cleaned up both ocv, and applied 12v to operate them, and cleaned further in both positions. They both snap open / shut cleanly. Plugging them back in today, to test out. Perhaps my gassy smell was just from the rich exhaust, and my shitty rear hatch latch, or who knows. Find that problem next. Link to comment Share on other sites More sharing options...
ttnio Posted March 17, 2020 Share Posted March 17, 2020 nice job Link to comment Share on other sites More sharing options...
covertrussian Posted March 17, 2020 Author Share Posted March 17, 2020 Those were common in pre-2005 EJ255's too, it just happens that by 2005 USDM Legacy's didn't have them. I detail the removal of those in How to Remove All Banjo Filters 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
