kaluce Posted May 10, 2017 Share Posted May 10, 2017 I was curious about this. It's well known that stiffer bushings will produce more NVH as a side effect of the material's properties used. Is it possible to minimize the N portion of the NVH that the bushings produce using products like dynamat, and if so, where would be a good place to apply it? Link to comment Share on other sites More sharing options...
RocketOgre Posted May 13, 2017 Share Posted May 13, 2017 I've put some serious amounts of dynamat and other off-brand sound deadener into cars. You can reduce exhause noise a bit by doing the floors and whatnot, in the door skins/around the speakers helps a lot, but really most tar matting is to make the stereo sound better by stopping the sheet metal from rattling. Especially if you aren't coating everything. A complete package like the one below is as good as it gets for sound deadening. You'll think you're in a new MB if you do everything they say. https://www.sounddeadenershowdown.com/ Link to comment Share on other sites More sharing options...
