oconnor Posted May 5, 2017 Share Posted May 5, 2017 05 LGT wagon Auto trans. The prop shaft needs to be replaced, is there an alternative to a new Subaru shaft. Dorman makes one but have seen nothing but bad reviews so not interested in going that direction. The driveshaft shop makes one piece shafts for WRX any one ever had one made for LGT? Not putting a used shaft in either. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 5, 2017 Share Posted May 5, 2017 google search, I'm sure you'll find the threads on here about them. I replaced mine with a OEM shaft a few years back. JmP's sticky about various parts, up top has info too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
freaksavior Posted May 5, 2017 Share Posted May 5, 2017 I would do one of two things. A) Find a driveline shop; I'm sure they can make you one. If you were near Houston, i'd have a recommendation too. B) What Max said. Find the part number or call your dealer to get an OEM unit and call it a day. If I was in your shoes, i'd find a driveline shop that can make you an aluminum one piece. Link to comment Share on other sites More sharing options...
quick4dr Posted May 5, 2017 Share Posted May 5, 2017 Love my 1 piece shaft from Drive Shaft shop. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 5, 2017 Share Posted May 5, 2017 got this from JmP's sticky about "various parts" I've been meaning to contact them about making a prop shaft for these cars, I wonder if they would ? May be somebody should call them... "Found good info in post # 724 in this thread about Raxles. May be one of the MOD's can this link up so the whole thread doesn't take up band width. I just want to give credit to the OP that found this info. NORULZleggy http://legacygt.com/forums/showthrea...108975p19.html From raxles site, The best way to order is to just give us a call on our toll-free (800-257-8192) line for immediate access to a professional axle specialist with a minimum of 15 years in the CV axle field. Or just email ( sales@raxles.com ) us for a fast quote or with any questions. Our hours are 8:00 to 5:00, EST Monday through Friday " 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
oconnor Posted May 6, 2017 Author Share Posted May 6, 2017 Gonna call Driveshaft shop on Monday. New Subaru prop is more than the one piece shaft. Link to comment Share on other sites More sharing options...
