05leggygtltd Posted April 30, 2017 Share Posted April 30, 2017 My front caliper seized up on me and I have available to me some cheap 03 wrx calipers. I know the answer is already out there somewhere but I have information oversaturation at this point. I'm just wondering if it would be a worthy upgrade seeing as to how I plan on doing the rotors and pads soon anyway. I realize that the rears are probably not compatible without some work or an adapter, but are these 2 pots worth the hassle over my 1 pots? Obviously buying a $70 replacement caliper and swapping it out is easier and cheaper, but I hate to miss a chance at an upgrade that'll only cost slightly less than the maintenance I'll be doing anyway. For the record, I dont track or really do anything out of the ordinary. Some minor work and a tune has me at 260 hp so I'm not in need of much. Thanks in advance Link to comment Share on other sites More sharing options...
LatentWagen Posted April 30, 2017 Share Posted April 30, 2017 My front caliper seized up on me and I have available to me some cheap 03 wrx calipers. I know the answer is already out there somewhere but I have information oversaturation at this point. So if the information is spoon-fed to you, you're no longer over-saturated? The problem is that the information you've gorged on is erroneous. Best to forget everything and start over, with a good search I'm just wondering if it would be a worthy upgrade Not an upgrade. Your LGT brakes > WRX brakes. but are these 2 pots worth the hassle over my 1 pots? You currently have 2-pots already. Some minor work and a tune has me at 260 hp so I'm not in need of much. Your stock brakes are fine. Replace the caliper and get on with enjoying the car! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
05leggygtltd Posted April 30, 2017 Author Share Posted April 30, 2017 Thank you for the reply. I realize looking through these forums how many times the same questions are asked, I appreciate the non flame Lol. I was hoping that was the answer I'd get so I can spend more time and money elsewhere. Thanks again Link to comment Share on other sites More sharing options...
