Rossabal Posted April 25, 2017 Share Posted April 25, 2017 Hey Guys Recently came into a genuine Nardi Classic Steering wheel. Looking to install in my 2005 LGT. Yes I know its frowned upon as I will be removing my factory airbag. However, cant find the info with regards to which steering wheel hub I need and which airbag resistor ? I have a Subaru aftermarket hub (from my 02 WRX) and believe this may work ? Anyone able to answer those questions for me ? Cheers Ross Link to comment Share on other sites More sharing options...
MPacMan15 Posted April 29, 2017 Share Posted April 29, 2017 I've thought about this as well, the correct hub is the nrg srk105h. It will keep the clock spring in working order and I believe it comes with the fuse for the airbag Link to comment Share on other sites More sharing options...
Rossabal Posted April 29, 2017 Author Share Posted April 29, 2017 Actually the SRK 100h appears to be the correct one for our cars. I have a hub from my old 03 WRX and according to NRG website it should be compatible. And after some extra research it should be 2.2ohm resistor that's used. Link to comment Share on other sites More sharing options...
MPacMan15 Posted April 29, 2017 Share Posted April 29, 2017 from what I've been told the one for the legacy does not keep the clock spring which is why people use the wrx/sti one because the steering column is the same Link to comment Share on other sites More sharing options...
Rossabal Posted April 29, 2017 Author Share Posted April 29, 2017 Oh I see I hadn't known that! Would be nice to hear what people have been using. Link to comment Share on other sites More sharing options...
SoMD_GT Posted March 23, 2018 Share Posted March 23, 2018 So what's the answer to this? I have an aftermarket momo I wanna use Link to comment Share on other sites More sharing options...
