rumbleintheboxer Posted April 10, 2017 Share Posted April 10, 2017 Anyone been through this before.. seems the body twist may have sheared the head off and I see no threads to grab on to or weld a nut to it. http://imageshack.com/a/img923/4230/v4B8fe.jpg Link to comment Share on other sites More sharing options...
Das Ninjabot Posted April 10, 2017 Share Posted April 10, 2017 Looks like you may have to use an extractor or drill that one out. I'd clean that area well and spray some penetrant on it and let it sit for awhile before heating it up and then using an extractor. Link to comment Share on other sites More sharing options...
doublechaz Posted April 10, 2017 Share Posted April 10, 2017 You mean the female threads are full of the broken off male threads evenly, right? If you meant you have a hole with no female threads then the welded backside nut broke off and no one did anything to fix it, just use a nut and bolt. But you probably meant you need to drill a hole and use an extractor. Link to comment Share on other sites More sharing options...
rumbleintheboxer Posted April 11, 2017 Author Share Posted April 11, 2017 Yeah exactly, the female threads sheared flush. No female threads showing. I may have to pull the plate completely off but I'll need to remove that stud so I can find the thread pitch, and I'm worried I'll snap the others in the process. If anyone is wondering why there is so much grease, it came from an exploded cv joint I've since replaced. Thanks guys, this is more of a money pit than both my Cherokees, and jeep stands for just empty every pocket! Will update soon. Link to comment Share on other sites More sharing options...
Setnev Posted April 11, 2017 Share Posted April 11, 2017 On my jack plate, there is actually 2 nuts on the other side of the crossmember where your bolt broke. Link to comment Share on other sites More sharing options...
