Smokeyjo Posted March 15, 2017 Share Posted March 15, 2017 Got new handle. Have to paint. Can't t get broken handle out. Removed two bolts from inside after inside panel off. Lock slips out, found broken piece. But I can not budge handle and I can't see in there to see what's holding it. Anybody explain it to me? Thanks Link to comment Share on other sites More sharing options...
CapnJack Posted March 16, 2017 Share Posted March 16, 2017 There are two plastic clips molded on the bottom of the handle that lock it into the door. If you are not careful they will brake if you pry too hard. You will need to bend the metal slightly from the inside and lift the handle out of the door to get them out. Link to comment Share on other sites More sharing options...
