ibhknl Posted March 12, 2017 Share Posted March 12, 2017 Just looking for some opinions on my block prep for the new gaskets. I used a 3m Roloc Bristle Disc to clean the mating surface, along with a little work with a green scotchbrite pad to get surface areas not reachable with the disc. I used the roloc, scotchbrite, and small flathead screwdriver on the pistons. Heads are coming home from the shop tomorrow. How does the gasket surface look? Good to go? Still a little gasket color in a few places but its smooth as can be to the touch. https://multimedia.3m.com/mws/media/629878O/3m-roloc-bristle-discs.pdf Link to comment Share on other sites More sharing options...
RustyRuu Posted March 12, 2017 Share Posted March 12, 2017 what is your deck surface warpage at? how flat was it? Link to comment Share on other sites More sharing options...
ibhknl Posted March 13, 2017 Author Share Posted March 13, 2017 I used a straight edge and feeler gauge. Warpage, if any, is so minimal it was hard to quantify. Link to comment Share on other sites More sharing options...
RustyRuu Posted March 13, 2017 Share Posted March 13, 2017 It should be good to go or it looks and sounds like you have it covered. Be sure to move those prisons to mid stroke before putting your heads and then adjust and check your valves before putting the valve cover on. Have you gotten a new timing kit yet, gates kits are not what they used to be just do a search here. I'm on my phone at work and can't paste the link. Just something to look into. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2017 Share Posted March 13, 2017 You are installing ARP head studs, right ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RustyRuu Posted March 14, 2017 Share Posted March 14, 2017 Head studs sound like a royal pain with the short block still in the vehicle. Do you think it's still possible? I mean everything is possible but, what do others think? And it's only a SOHC block would studs be overkill? Link to comment Share on other sites More sharing options...
ibhknl Posted March 14, 2017 Author Share Posted March 14, 2017 Thanks for the advice. Wait, studs? There are (bolt in)studs! Where might a gentleman acquire them? Planned to reuse the bolts, need car next week, thoughts? Link to comment Share on other sites More sharing options...
ibhknl Posted March 15, 2017 Author Share Posted March 15, 2017 Motor is still in the car, but I cant get the drivers side head back on. Anyone have tips or a good thread/video on this? Can it be done? Link to comment Share on other sites More sharing options...
RustyRuu Posted March 15, 2017 Share Posted March 15, 2017 You can undo the bottom nut for the mount on that side and try and Jack it up maybe put a 2 by 4 under it to hold it in place without the jack. It might give you a bit more clearance.. Link to comment Share on other sites More sharing options...
ibhknl Posted March 16, 2017 Author Share Posted March 16, 2017 That worked! Got the heads on. I have not began torquing yet but my passenger side gasket looks a bit funny, is it ok? Drivers side is all "together". Link to comment Share on other sites More sharing options...
ibhknl Posted March 16, 2017 Author Share Posted March 16, 2017 That worked, got the heads on. I have not began torquing yet but my passenger side gasket looks a bit funny, is it ok? Drivers side is all "together". Link to comment Share on other sites More sharing options...
Max Capacity Posted March 18, 2017 Share Posted March 18, 2017 Any updates ? it's been 3 day's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ibhknl Posted March 18, 2017 Author Share Posted March 18, 2017 Yeah, thanks for asking. Loosened the head up and re-torqued to 10 ft. Got a little better. Torquing this head down in just a few min. Going to complete assembly and I'll let y'all know how it goes. Hope to be done today!!!! Is the Subaru head conditioner necessary on this model? Any advice on "break in"??? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 20, 2017 Share Posted March 20, 2017 I just use Peak Global anti-freeze or Prestone, have never used the that conditioner. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
