cerrone Posted March 11, 2017 Share Posted March 11, 2017 Hello guys. I slowly started to destroy the stock audio and replacing it with some after market parts. This is one of the worst sounding stock systems I ever listened. They didn't install tweeters in the dash locations at all - probably offering them as an upgrade. I will install a new palyer, 2 amps and an active 2-way front. Before I begin with disassembly I got a quick question to you - how you run your wires through the plastic wire passage, which I'm pointing at the photo, from the front to the trunk? Is there a way to remove the carpet and disassemble it? Should I just pull it out or it is secured somehow? Link to comment Share on other sites More sharing options...
