Cerebral_1 Posted March 7, 2017 Share Posted March 7, 2017 Hey guys, wanted to get your input on a strange mechanical issue on my 05 OBXT (118k mi) that started just 3 days ago right before a road trip (of course!). I can hear a scrape-y squeal and clunk sound when rolling in neutral (when off the brakes) in a parking lot; it doesn't really change if I have the brakes applied or not. The noise stops when the car stops moving. Sounds like from driverside rear. I don't think it's a wheel bearing, as I replaced with a brand new OEM unit on that side about 18 months ago or less than 20k miles ago. At first, I thought it was the squealers on the brake pads, indicating wear...but that doesn't explain the clunk, which sounds like something is broken. Also, when going over bigger bumps or uneven pavement at highway speed, I get a grind-y "pop" sound from that side (audible at hwy speed). I'll jack it up and look underneath tomorrow. In the meantime, wanted to get your thoughts. What could this be?! Did my parking brake assembly explode? Could it be something else, maybe related to suspension? I'm hoping it's something stupid like a bent dustshield, but probably not. Coincidentally (may or may not be related), around the same time this all started, my parking brake needed to be pulled up higher and higher to engage. Now, the brake dashlight comes on if I barely move the handle. Link to comment Share on other sites More sharing options...
Cerebral_1 Posted March 7, 2017 Author Share Posted March 7, 2017 Bump for some ideas of things to check out in the morning... Link to comment Share on other sites More sharing options...
Cerebral_1 Posted March 7, 2017 Author Share Posted March 7, 2017 Bump for help! Link to comment Share on other sites More sharing options...
fedaykin Posted March 8, 2017 Share Posted March 8, 2017 Have you pulled the wheel off to have a look? Could be parking brake related. Link to comment Share on other sites More sharing options...
Dishwasher Posted March 9, 2017 Share Posted March 9, 2017 Parking brake might be rubbing, there's a manual adjustment gear behind a little rubber dust cover on the inside of the brakes. I think if you spin the gear down it should loosen up the parking brake. See if that fixes it (keep your car in gear so it doesn't roll away). Bad sway bar end links and or bushings could be the cause of clunking over bumps. If you are still on the original end links and bushings they are likely shot. I have moogs which were inexpensive and much better than OEM replacements. You can get them at advanced auto parts or online. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
GTEASER Posted March 9, 2017 Share Posted March 9, 2017 Sounds like the parking brake. You need to pull the rotor off to look at it. 2 M8x1.25 bolts about 1.5" long to screw into the holes in the drum will help you get it off. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
